Author Topic: Need a script to delete a specific block in PaperSpace  (Read 6399 times)
Re: Need a script to delete a specific block in PaperSpace
« Reply #15 on: October 09, 2014, 03:32:51 PM »
You have to supply the block names .. like so:
(remstamp "REMBLOCK,FORCONSTRUCTION")
Hummm, I don't think so.
Something else causing the error.
« Reply #16 on: October 09, 2014, 03:36:57 PM »
I get that, but I can't use it at the command prompt that way if I load the lsp...
Awesome for running with SCRIPT PRO.  but what could we do to get it to work at the command prompt.. ultimatly multiple options are very cool, but being aple to type the comand.. hit enter then type the block name would be ideal.  like mentioned before, one could always script it to run twice
remstamp
forconstruction
remstamp
forapproval
qsave
It would be handy to have at the command prompt while in the file as much as just for scripting use.
Does that make sence?
most of the crew i work with don't even know how to make .scr files.. so I got to get it simpler.
Look at this subroutine:
http://www.theswamp.org/index.php?topic=2688.msg34342#msg34342
DIW_CADtech
  • Push limits, embrace success, & discard failure.
« Reply #17 on: October 09, 2014, 03:54:33 PM »
OK..
I have two blocks in the drawing,
one named DEMOLITON and one named FORCONSTRUCTION
I paisted
and
(remstamp "DEMOLITION,FORCONSTRUCTION")
both times the purge seems to run but then I get this at the command prompt
I even typed it in instad of paisting .. i attached the lsp and the DWG.
Command: ; error: bad argument type: consp "REMBLOCK,FORCONSTRUCTION"
Command: ; error: bad argument type: consp "DEMOLITION,FORCONSTRUCTION"
I even re-copied your code, resaved the .lsp file, and reloaded the lsp. and ran it a second time...
something.. aint right.
I am very  trainable....   (forgive my spelling)
DIW_CADtech
« Reply #18 on: October 09, 2014, 03:59:00 PM »
I don't know how to implement the subroutine.. I'm not good at writing the code.. I had a rough time following the script above.. the subroutine is way over my head. .
« Reply #19 on: October 09, 2014, 06:37:46 PM »
This is how I'd do it.
Use the enclosed lisp File.
Use a script file for each combination of blocks ; each file with a unique name.
If used manually, type SCRIPT at the command line and select the appropriate script.
If used with ScriptPro, call the appropriate script.
  1. ;; RemStamps.lsp
  2. ;; MODIFIED CODE 2014/10/10
  3. ;; Codehimbelonga kdub@theSwamp 2014/10/08
  4.
  5. (defun remstamp (blknames / blkname)
  6.   (setq exprt (getvar "expert"))
  7.   (setvar "EXPERT" 5)
  8.   (command "-layer" "set" "0" "")
  9.   (command "Zoom" "All")
  10.   ;;
  11.   (if
  12.     (setq ss (ssget "X" (list '(0 . "INSERT") (cons 2  blknames))))
  13.      (while (setq block (ssname ss 0))
  14.        (vla-delete (vlax-ename->vla-object block))
  15.        (ssdel block ss)
  16.      )
  17.   )
  18.
  19.   (vl-cmdf "_.Audit" "Y")
  20.   (repeat 3 (command "-PURGE" "ALL" "*" "N"))
  21.   (setvar "EXPERT" exprt)
  22.   (command "QSAVE")
  23.   (princ)
  24. )
  25.
  26.
  1. ;;;;; RemStamp-01.scr
  2. (LOAD "P:\\DWells\\LSP\\REMOVE_Block\\REMSTAMP.lsp")
  3. (RemStamp "FORCONSTRUCTION,DEMOLITION")
  4.
  1. ;;;;; RemStamp-02.scr
  3. (RemStamp "CONSTRUCTION,DEMOLITION")
  4.
  1. ;;;;; RemStamp-03.scr
  3. (RemStamp "FORCONSTRUCTION,SPECIALNOTES")
  4.
  1. ;;;;; RemStamp-04.scr
  3. (RemStamp "HOLDFORINFORMATION,SPECIALNOTES,REVIEWSTAMP")
  4.
« Reply #20 on: October 09, 2014, 07:10:46 PM »
Just for info, I've used this to update/revise a block in multiple drawings, via ScriptPro.
Particularly handy when 'someone' misspells something in a block that is inserted into hundreds of drawings.
  1. ;;(updateReviewStamp "FORREVIEW" "FORCONSTRUCTION")
  2. ;; Rev 2011.08.07
  3.
  4. (defun updateReviewStamp (oldBlock newBlock)
  5.   (setq exprt (getvar "expert"))
  6.   (setvar "EXPERT" 5)
  7.   (command "-layer" "set" "0" "")
  8.   (command "Zoom" "All")
  9.   (repeat 3 (command "-PURGE" "ALL" "*" "N"))
  10.   ;;
  11.   (if (setq ss (ssget "X" (list '(0 . "INSERT") (cons 2  oldBlock))))
  12.         (progn
  13.           (vl-cmdf "_.rename"
  14.                            "block"
  15.                            oldBlock
  16.                            newBlock
  17.           )
  18.           (vl-cmdf
  19.                   "_.Insert"
  20.             (strcat newBlock "=P:\\ProjBlocks\\" newBlock ".dwg")
  21.                 (list 0. 0. 0.)
  22.                 1
  23.                 1
  24.                 0
  25.           )
  26.           (vl-cmdf "_erase" (entlast) "")
  27.         )
  28.   )
  29.   (vl-cmdf "_.Audit" "Y")
  30.   (repeat 3 (command "-PURGE" "ALL" "*" "N"))
  31.   (setvar "EXPERT" exprt)
  32.   (command "QSAVE")
  33.   (princ)
  34. )
  35.
  36.
DIW_CADtech
« Reply #21 on: October 09, 2014, 08:34:04 PM »
This seems to be work'n.   Thanks Everyone..
 :wink:
« Reply #22 on: October 09, 2014, 10:46:28 PM »
Sorry Ron I thought you were talking about my code.
I'm slipping, need more sleep. :(
« Reply #23 on: October 10, 2014, 08:48:34 AM »
No worries Charles  :)
