Going through loops.
Municipality requires that we deposit PDFs that include "For Construction" Stamp into their proprietary web based interface. They also require us to upload our CAD files and PDF's without the "For Construction" stamp to a different Web Based interface.
We've got a small set of 55 dwgs.. and I've already put the stamp in all 55 dwgs. So I can publish the set to PDF and create the initial PDF's with "For Construction" but I don't want to individually open 55 files to remove the stamp. FYI the block name is FORCONSTRUCTION. I utilize SCRIPT Pro and so I can run an .scr file on all the dwgs in the set, but I don't know how to write the .scr file so that it will erase a specific block with the name of "FORCONSTRUCTION".
oh.. fyi.. the block is not in the same place on every dwg.. we have 11x17's, 42x30, and 24x36, and some really odd sizes.
The stamp is in PS in all the dwgs thou.. I put them in.. so I know.
I've considered doing a simple block swap.. having the replacement block just have linework on defpoints so it doesn't plot.. but I know the municipality would rather the block just be gone.
FYI this municipality doesn't allow XREF's.. dwgs must be 100% stand alone items prior to upload. and broken XREF's is a no-no.. (red flag's their system)
