Author Topic: 3D polylines from corridor?  (Read 3545 times)
DPATTERSON
« on: October 06, 2014, 01:40:20 PM »
Hello everyone,
I was wondering if it is possible to have CAD build a 3D poly line from a corridor.  My assembly contains day lightning for the ditch line and I need to create a 3D poly line with the elevations created by the day lightning for the ditch line.
Thank you in advance.
Matt__W
  • I like my water diluted.
Re: 3D polylines from corridor?
« Reply #1 on: October 06, 2014, 01:43:14 PM »
Can you extract objects from a corridor like you can from a surface??
Autodesk Expert Elite
DPATTERSON
« Reply #2 on: October 06, 2014, 02:09:54 PM »
No i am unable to extract objects
« Reply #3 on: October 06, 2014, 02:30:01 PM »
select the corridor
from Launch Pad
chose - create feature line from corridor
pick your desired feature line (point code) from the corridor
*upon exploding the feature line becomes a polyline, yet retains ALL elevation details
