Hey guys, thank you for your thoughts, here's what I'm using;
My drawing Units are set to Decimal w/ a Precision of 0.0000 ((4) decimal places) w/ the insertion scale set to Centimeters.
My Primary dimensions are Architectural w/ a Precision of 1/8", scale factor of 1.0000.
My Secondary dimensions are Decimal w/ a Precision of 0.000, multiplier for alt units @ 2.5400 (Centimeters)
Using the Convert tool (
https://joshmadison.com/convert-for-windows/), I have the following (pic attached)
As you can see, 9.8333 feet (9'-10") is 299.7199 centimeters (my drawing shows 299.726 (fractions of an inch difference))
The Primary dimension scale factor of 1.0000 controls the overall dimension scale so the Secondary dimension still uses the scale factor of 1.000 & multiplies the alt units of 2.54 to get the centimeters, correct?
Perhaps I am seeing this incorrectly & my drawing units & distance are correct & my dimensions are wrong?
