Author Topic: Boundary problem  (Read 3227 times)
Fabricio28
Boundary problem
« on: October 03, 2014, 11:13:51 AM »
Hi guys,
I'm trying to create a boundary, but isn't working properly.
I'm attaching a file example.
Thank in advance
Re: Boundary problem
« Reply #1 on: October 03, 2014, 11:28:11 AM »
I get no error
select object (polyline)
enter BOUNDARY command
pick internal point
I object is created (polyline) boundary
as I can not produce the error
I can not offer a solutuon
perhaps ensure your polyline is closed
and flattened
« Reply #2 on: October 03, 2014, 11:29:13 AM »
change your units. make the precision much larger.
RC
« Reply #3 on: October 03, 2014, 12:14:56 PM »
as Mark points out, bump LUPREC to 4 or 5 and it works fine, I also discovered that even with lower values of LUPREC it will work (in this case) if you zoom into that corner.
RC
« Reply #4 on: October 03, 2014, 12:16:00 PM »
I get no error
Did the new boundary polyline follow the little 'tick in the corner indicated or did it jump that corner???
« Reply #5 on: October 03, 2014, 12:25:59 PM »
it appeared to be correct....
Fabricio28
« Reply #6 on: October 03, 2014, 12:52:38 PM »
Thank you guys for the quick replay
I've noticed if I zoom extend and create boundary in the center, didn't work.
But if I zoom windows where the boundary isn't work and create. It works perfect!
It is any bug in autocad?
I don't know what's wrong, I changed the units and didn't work.
RC
« Reply #7 on: October 03, 2014, 01:00:19 PM »
Not the units, but the precision, the setvar is LUPREC setting it to 4 or 5 works here.
Apparently it is a rather new bug, I bumped the file back to 2002 and opened it in 2002 and it worked fine even with a low LUPREC setting.  Another 'feature' perhaps??
Fabricio28
« Reply #8 on: October 03, 2014, 01:05:00 PM »
Command: luprec
Enter new value for LUPREC <2>: 5
Didn't work here.
RC
« Reply #9 on: October 03, 2014, 01:07:06 PM »
Command: luprec
Didn't work here.
hmmm.... works here AutoCAD 2013 what version are you running??
Fabricio28
« Reply #10 on: October 03, 2014, 01:19:43 PM »
Command: luprec
Didn't work here.
autocad 2012 32bits
RC
« Reply #11 on: October 03, 2014, 03:50:04 PM »
dunno ... odd
2013 - 64
