Author Topic: Corridor not building on Surface?  (Read 3366 times)
DPATTERSON
« on: October 03, 2014, 10:12:40 AM »
Ok gang prepare yourself.  I have to build this corridor along an alignment for a road.  I perform data preparation for GPS survey equipment, I usually get sent a file and have to create a surface based on grade markers or build exact models of a parking lots, roads, etc...  I have to build a corridor on an alignment for a road and when i run through the process everything goes right until it builds the corridor surface.  There are no errors, however i cannot see the corridor along the alignment and there are no lines associated with corridor visible.  First thing I did was check the styles to make sure everything was visible in plan and model. I tried opening and closing the file, altering the target surface, trying a different assembly, and nothing.  I'm hoping its nothing and one of you guys can point me in the right direction.
Thank you in Advance
-David
Re: Corridor not building on Surface?
« Reply #1 on: October 03, 2014, 10:14:44 AM »
wrong code set
applied to either or
or both
the assemblies
the corridor
also check view style
and or level of detail
DPATTERSON
« Reply #2 on: October 03, 2014, 10:24:12 AM »
How would that work with the Code sets they are standard sub-assemblies?
« Reply #3 on: October 03, 2014, 10:42:22 AM »
They may be standard assemblies,
however the wrong code set could cause certain things to be invisible that should otherwise be visible.
also wondering what your frequency settings are...
and or if OMIT links toggle has been toggled
also a common 'miss-step' from many students
they create the corridor surface - yet fail to include any links (TOP) in that surface so nothing shows up.
as they have created a surface containing NO DATA.
« Reply #4 on: October 03, 2014, 12:59:10 PM »
you have layers that are OFF and or FROZEN
check your layers and layer standards.
« Reply #5 on: October 03, 2014, 01:00:48 PM »
also check the start and end of your profile there are issues..... heads -up
DPATTERSON
« Reply #6 on: October 03, 2014, 01:23:00 PM »
Checked my layers and layer standards, turned on all display layers and any additional layers that were off.  I also fixed the profiles, Still not displaying Corridor.
« Reply #7 on: October 04, 2014, 07:31:36 AM »
sending file back to you...with corridor on.
