Ok gang prepare yourself. I have to build this corridor along an alignment for a road. I perform data preparation for GPS survey equipment, I usually get sent a file and have to create a surface based on grade markers or build exact models of a parking lots, roads, etc... I have to build a corridor on an alignment for a road and when i run through the process everything goes right until it builds the corridor surface. There are no errors, however i cannot see the corridor along the alignment and there are no lines associated with corridor visible. First thing I did was check the styles to make sure everything was visible in plan and model. I tried opening and closing the file, altering the target surface, trying a different assembly, and nothing. I'm hoping its nothing and one of you guys can point me in the right direction.
Thank you in Advance
-David
