Author Topic: (type (read item))  (Read 6268 times)
Peter Guappa
Re: (type (read item))
« Reply #15 on: October 01, 2014, 05:46:37 PM »
weird....
: (setq a "0.01")
"0.01"
: (atof a)
0.01
: (type (read a))
SYM
: (setq b a)
"0.01"
: (type (read b))
REAL
: (type (read a))
SYM
hmspe
« Reply #16 on: October 01, 2014, 07:21:47 PM »
Could I ask what software you are using and which version?  Are you loading any lisp routines or third party add-ons?  Have you tried rebooting and re-testing?  I have seen some strange things in Bricscad when local variables in lisp routines are not properly localized, but it only happens after several hours of using the program.  As far as I can tell the un-localized variables accumulate and eventually outgrow the alloted memory space and start overwriting other parts of the program's memory space.
"Science is the belief in the ignorance of experts." - Richard Feynman
Peter Guappa
« Reply #17 on: October 01, 2014, 11:00:50 PM »
The first time it happened, the machine was running on Bricscad 13.2.8, so I upgraded to v13.2.10 and also tried evaluation copy of v14.
Without luck.
No 3rd party software is installed.
We do use our own routines, but they run fine on 40 other machines, running on different versions of Bricscad and Autocad.
hmspe
« Reply #18 on: October 01, 2014, 11:23:18 PM »
I recommend filing a bug report at the Bricscad site.  I'm not sure they can duplicate the problem but I'm sure someone there will look.
Your code worked properly on V14 here.
« Reply #19 on: October 02, 2014, 12:18:00 AM »
As a general recommendation :
If the issue is related to a specific application please mention the application and build in the original post.
I had assumed the problem related to AutoCAD 2015 ...  :|
Have a little respect for the time and effort expended by people trying to assist solve the issue.
« Reply #20 on: October 02, 2014, 12:40:07 AM »
Do you mean the Windows setting?
In Windows the dot (.) is set as decimal separator.
On the machine returning SYM is comma a decimal separator? Its a very common problem when dealing with multiple regions.
http://www.copsmodels.com/gpcommapnt.htm
Great link Chris.
irneb
« Reply #21 on: October 02, 2014, 02:17:29 AM »
Without luck.
Cop-out answer (sorry):
Have you tried uninstalling completely and then reinstalling? Sometimes a bug might have crept in (e.g. bad hard drive) and simply upgrading/updating doesn't always replace all the files.
snownut2
  • Bricscad 22 Ultimate
« Reply #22 on: October 02, 2014, 02:51:22 AM »
another test I did
: (setq a "0.01")
"0.01"
: (atof a)
0.01
: (type (read a))
SYM
Works for me... Bricscad 14.2.17
: (type(read "0.01"))
REAL
« Last Edit: October 02, 2014, 02:55:21 AM by snownut2 »
roy_043
  • BricsCAD 18
« Reply #23 on: October 02, 2014, 04:07:45 AM »
Tested on BC V13.2.10:
(type (read "0.01")) => REALThe OS setting for the decimal separator makes no difference (dot or comma).
roy_043
  • BricsCAD 18
« Reply #24 on: October 02, 2014, 04:12:45 AM »
Peter Guappa
« Reply #25 on: October 02, 2014, 07:35:57 AM »
updating bricscad => no luck
reinstalling bricscad => no luck
reinstalling as administrator = SUCCES
Thanks Roy !
« Reply #26 on: October 02, 2014, 08:24:21 AM »
« Reply #27 on: October 02, 2014, 09:26:54 AM »
Roy great job!
roy_043
  • BricsCAD 18
« Reply #28 on: October 03, 2014, 02:55:07 AM »
I am glad that I was able to help. But I don't know if digging something up from the (very) back of your mind qualifies as 'sleuthing'. :-D
« Reply #29 on: October 03, 2014, 08:20:02 AM »
Hummm. I have a hole back there and every time I add something, something else gets pushed out.  :(
