Author Topic: AutoCAD 2015 slower for keystrokes  (Read 2988 times)
Jeff H
« on: September 30, 2014, 11:31:01 AM »
Has anyone else had problems when typing fast with 2015 like typing "CO" enter, and the circle command starts.
It seems not able to keep up and really getting annoying.
Rob...
Re: AutoCAD 2015 slower for keystrokes
« Reply #1 on: September 30, 2014, 11:32:12 AM »
Maybe tweaking the settings for auto-complete will help.
CAD Tech
Jeff H
« Reply #2 on: September 30, 2014, 11:37:29 AM »
Tried turning all of that off and still happens but will see if other setting work
Bethrine
« Reply #3 on: September 30, 2014, 11:42:10 AM »
Yes. If I type "str" for "stretch" and hit the space bar too fast it says no such command.
« Reply #4 on: September 30, 2014, 12:06:26 PM »
No problems here.
huiz
  • Certified Prof C3D
« Reply #5 on: September 30, 2014, 01:50:49 PM »
Indeed, setting INPUTSEARCHDELAY to 2000 did help here a bit.
But yes, it is dramatical slow and bad responding. With the Selection Cycling on, most times the focus of the commandline is lost so it does not react to an Enter, have to press it twice, if not the InputSearch found some completely other command yet. In Civil3D I noticed also that if I click on a Civil3D object, the activation of a contextual Ribbon also sometimes result in a lost focus of the drawing area.
Jeff H
« Reply #6 on: October 10, 2014, 09:59:10 PM »
Just in case you did not see this thread
AutoCAD Latency Issue
