Author Topic: PacMan And Planet Zog - Final upgrade/posting  (Read 5025 times)
RAIN CODE
« on: September 30, 2014, 06:37:00 AM »
Hi guys,
This is the final posting/upgrade for the PacMan game (lisp dated 27.09.2014 - Final). Been writing the same game for too long, want to try another game now.
Am thinking of a simple easy to write game and also try out irneb suggestion using a new approach of regulating the game speed.
This final posting consisits of 100 game levels, 13 backgrounds all with lighting effect and more options for the StartUp menu.
Watch the video here at Youtube:
http://youtu.be/Z2HhGPIaZd0
download the PacMan zip file here at the links below:
http://www41.zippyshare.com/v/75791983/file.html
download the lisp below here at the swamp
(You need to be a member of TheSwamp to download this lisp)
tombu
  • ByLayer=>Not0
Re: PacMan And Planet Zog - Final upgrade/posting
« Reply #1 on: September 30, 2014, 06:42:20 AM »
What versions of AutoCAD will this work on?  Didn't have an old enough version to run your original.
Tom Beauford P.S.M.
andy_lee
« Reply #2 on: September 30, 2014, 07:22:59 AM »
+1 , if only support cad2002 ,It doesn't make any sense to update more .
Zip file is so big (186.74MB) , why we need use cad to play this game ?  I download a EXE file ,Perhaps only a few megabytes !
« Last Edit: September 30, 2014, 07:29:38 AM by emk2012 »
andy.
Best regards.
bilançikur
« Reply #3 on: October 01, 2014, 07:09:37 AM »
... why we need use cad to play this game ?  I download a EXE file ,Perhaps only a few megabytes !
I believe it is about someone showing his (or hers) capability and skills in programming an AutoCAD enviroment.
It is not about why you need to do this or that. You do not need tdo anyting. I'd suggest you'd just play the exe variant.
By the way,the last time I worried about how big a file was, was when I as burning movies on DVDs
« Reply #4 on: October 02, 2014, 01:32:14 AM »
I don't think it is fair to hotlink this size file to theSwamp and expect Mark to pay for the download bandwidth.
owenwengerd
« Reply #5 on: October 02, 2014, 11:47:34 AM »
20 downloads of a 1Mb file is like a tadpole in the Everglades.
« Reply #6 on: October 02, 2014, 11:54:40 AM »
I saw this and made an assumption
... didn't look closely enough at the original post.
RAIN CODE
« Reply #7 on: October 04, 2014, 04:24:14 AM »
tombu,
This only works on ver 2002. I tried on higher version but it didnt work - whole screen turned white
RAIN CODE
« Reply #8 on: October 04, 2014, 04:27:43 AM »
emk2012,
It isn't about the game. Its the challenge. I always wanted to write a PacMan game since I was in my 30's.
The zipped file size is big ...becos of the image and sound files
« Last Edit: October 20, 2014, 12:40:09 PM by RAIN CODE »
RAIN CODE
« Reply #9 on: October 04, 2014, 04:33:17 AM »
bilançikur ,
I would not dare to say I am skillful when I am in TheSwamp.
There are so many good programmers here that I look up to ... like Lee-Mac or CAB and others too.
RAIN CODE
« Reply #10 on: October 04, 2014, 04:35:55 AM »
 "is like a tadpole in the Everglades." ???  :blank: ???
RAIN CODE
« Reply #11 on: October 04, 2014, 04:37:12 AM »
But Kerry...it is only 1mb file size
 :-o
andy_lee
« Reply #12 on: October 04, 2014, 10:21:51 AM »
Hi RAIN CODE
You should study how to make it work in high version ,  Lee, CAB, should be very happy to help you !
andy.
Best regards.
RAIN CODE
« Reply #13 on: October 05, 2014, 06:19:03 AM »
Hi RAIN CODE
I like to make it to work on higher version too. But I dont know how.
I dont know about CAB or Lee, will they be free to help ?
RAIN CODE
« Reply #14 on: October 22, 2014, 02:12:59 AM »
Ya I know the EXE variant file is small but it only have 1 or 2 levels, it repeats the same levels (layout) but only with different type of fruit.
And the background is the same.
My zip file is big becos it contained the jpeg images for all levels, total are 103 levels (layouts) and there are 13 type of background with
 lighting effect, so we do the maths
103x13x (each jpeg file size is about) 125 kb = 167 mb then there are mp3 sound files thats why file size is so big.
And the lisp is 1mb but if to take out comments and the lisp for opening scene and demo I guess it only come to about 500 kb or
maybe less I didn't check it actually.
This late reply is becos I have so much time now (my Pc sent for repairing) that I ran thru' most posting until this one here.
