Author Topic: auto change the linetype sacle [ Not dynamic ]  (Read 2446 times)
77077
« on: September 29, 2014, 03:41:48 AM »
The ugly code , maybe have a better way !
  1. (defun Command_B()
  2.   (defun tmperr(msg)
  3.      (setq *error* nil)
  4.      (princ msg)
  5.      (command"_.undo""end")
  6.      (setvar"cmdecho"_sm_old_cmd)
  7.      (setvar"osmode"_sm_old_os)
  8.      (setvar"blipmode"_sm_old_bmd)
  9.      (setvar"highlight"1)
  10.      (setvar"elevation"_sm_old_elev)
  11.      (setvar"plinewid"_sm_old_plwid)
  12.      (setvar"pickstyle"_sm_old_picksty)
  13.      (setvar"cecolor" _sm_old_cecolor)
  14.      (setvar"expert"0)
  15.      (princ)
  16.   )
  17.    (setq *error* nil
  18.         _sm_old_cmd(getvar"cmdecho")
  19.         _sm_old_picksty(getvar"pickstyle")
  20.         _sm_old_os (getvar"osmode")
  21.         _sm_old_bmd(getvar"blipmode")
  22.         _sm_old_hlt(getvar"highlight")
  23.         _sm_old_elev(getvar"elevation")
  24.         _sm_old_plwid(getvar"plinewid")
  25.         _sm_old_ucsicon(getvar"ucsicon")
  26.         _sm_old_cecolor(getvar"cecolor")
  27.    )
  28.    (setvar"cmdecho"0)
  29.    (setvar"osmode"0)
  30.    (setvar"blipmode"0)
  31.    (setvar"thickness"0)
  32.    (setvar"elevation"0)
  33.    (setvar"plinewid"0)
  34.    (setvar"pickstyle"0)
  35.    (setvar"cecolor" "bylayer")
  36.    (command"_.undo""group")
  37.    (setq *error* tmperr)
  38.
  39. )
  40. ;;=====================================
  41. (defun Command_E()
  42.    (command"_.undo""end")
  43.    (setvar"cmdecho"_sm_old_cmd)
  44.    (setvar"osmode"_sm_old_os)
  45.    (setvar"blipmode"_sm_old_bmd)
  46.    (setvar"highlight"1)
  47.    (setvar"ucsicon"_sm_old_ucsicon)
  48.    (setvar"elevation"_sm_old_elev)
  49.    (setvar"plinewid"_sm_old_plwid)
  50.    (setvar"pickstyle"_sm_old_picksty)
  51.    (setvar"cecolor" _sm_old_cecolor)
  52.    (setvar"menuctl"0)
  53.    (setvar"expert"0)
  54.    (setvar"pickbox"4)
  55.    (setq *error* nil)
  56.    (princ)
  57. )
  58.
edit kdub :-> code=cadlisp-7
« Last Edit: September 09, 2015, 05:01:04 AM by ANJALI »
77077
Re: auto change the linetype sacle [ Not dynamic ]
« Reply #1 on: October 04, 2014, 10:29:45 AM »
someone have a look ?
RAIN CODE
« Reply #2 on: October 20, 2014, 12:21:08 PM »
you need to write the lisp yourself and if there are bugs  and you cannot solve it then post your program here they are happy to help you.
learn autolisp today it is not hard. start with the basic. I will help you if you are interested.
just like Autocad. when we first learn autocad we find it tough too but after learning it you find it easy to use. same thing to learning autolisp
« Last Edit: October 20, 2014, 12:25:18 PM by RAIN CODE »
