Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
3D transparency byblock, need some help
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 3D transparency byblock, need some help (Read 2726 times)
lamarn
Swamp Rat
on:
September 28, 2014, 04:15:57 PM »
I found a great routine to make blocks neutral (0, byblock, etc.)
The only thing missing is to set 'transparancy' byblock
I already made the dcl with a extra button
But the vla code does not seem to react.
Thanks in advance
Logged
flyfox1047
Guest
Re: 3D transparency byblock, need some help
Reply #1 on:
September 29, 2014, 03:52:18 AM »
Good familiar interface . It's really write by you?
Logged
lamarn
Swamp Rat
Reply #2 on:
September 29, 2014, 10:28:50 AM »
o it is not mine. I only wish i could do this. Can you?
I mailed the frenshman but no reaction from his side.
Me think I am the only person on earth using transparency 3D blocks byblock ..
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #3 on:
September 30, 2014, 03:44:43 AM »
Quote from: lammerts on September 28, 2014, 04:15:57 PM
Have you used (vlax-dump-object ...) to check for the right property?
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #4 on:
September 30, 2014, 05:29:10 AM »
Hint: the prop you are looking for starts with an 'e' and not with a 't'.
Logged
lamarn
Swamp Rat
Reply #5 on:
October 03, 2014, 08:14:39 AM »
This can be done outside the block / routine.
As for a start.
(defun c:Tpb ()
(setvar "TRANSPARENCYDISPLAY" 1)
(setq obj (ssget))
(if (/= obj nil)
(command "change" obj "" "p" "tr" "byblock" "")
(alert (strcat "Transparency ON and objects faded "ByBlock" "))
(princ "***Nothing Selected***"))
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #6 on:
October 03, 2014, 08:59:25 AM »
Perhaps this helps:
http://www.theswamp.org/index.php?topic=44517
Logged
lamarn
Swamp Rat
Reply #7 on:
October 03, 2014, 10:20:57 AM »
(vla-put-entitytransparency entity "byblock") ; something like that
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
