Author Topic: Does anyone have access to arcgis that would convert a SHP file to KMZ for me?  (Read 16794 times)
alanjt
  • Standby for witty remark...
As the subject says...pretty please?
Dropbox
one can do this with QGIS......
Or I will do it for you....post your SHP file
alanjt
Somehow I knew you'd come to the rescue. :)
I'd much rather go the route of being able/knowing how to convert it myself. Downloading now and I'll will post back if I have questions.
Thank you again, Michael.
Dropbox
I QGIS
ADD Vector Layer (your SHP file)
Select the layer
Rt-Click
Save as...
Output to KML or KMZ
or a host of formats....enjoy!
alanjt
Wow.
When it exports to to kml, it creates a folder for each object, which are named based on one of the object fields. Is it possible to specify which field(s) to use?
Dropbox
Wow.
suggest that you may be able to create a JOIN and link the information into a single file.....
or verify what KEYFIELD is being used from the SHP file's DBF
you may need to edit that to get desired result.
without seeing your data or results you desire it is tough to offer a blanket solution
alanjt
Nevermind, it asks you for the name field when you perform a saveas. I just typed it in and it exported perfectly. Thank you so much, Michael. This is pretty damn incredible. I'll have to make a donation.
Dropbox
Do you want my PAYPAL details also?    :-D
  • Custom Title
QGIS (A Free and Open Source Geographic Information System) http://www.qgis.org/en/site/
Cool. Thanks!
alanjt
I can't afford what I'm sure I owe you for all your time.
Dropbox
No worries it was (remains) a small joke...at least you are appreciative.  Enough said!
alanjt
Very appreciative.
Dropbox
BlackBox
FWIW -
In Civil 3D 2015 I use the new EXPORTKML Command - See Toolspace, Toolbox, Miscellaneous Utilities, Export KML, right click the nested Export KML, select Execute... menu item - to export projects to .KMZ, etc. for our clients.
I also use QGIS & ArcGIS trial installed on VM :wink:; the latter to extract data from .GDB which I've not (yet) found a way to do from QGIS.
Cheers
  • Custom Title
FWIW -
Nice! Glad to see they brought that back. :)
FWIW -
Cheers
http://gis.stackexchange.com/questions/22201/how-to-access-file-geodatabase-in-qgis
