Author Topic: Does anyone have access to arcgis that would convert a SHP file to KMZ for me?  (Read 16777 times)
BlackBox
FWIW -
In Civil 3D 2015 I use the new EXPORTKML Command - See Toolspace, Toolbox, Miscellaneous Utilities, Export KML, right click the nested Export KML, select Execute... menu item - to export projects to .KMZ, etc. for our clients.
I also use QGIS & ArcGIS trial installed on VM :wink:; the latter to extract data from .GDB which I've not (yet) found a way to do from QGIS.
Cheers
http://gis.stackexchange.com/questions/22201/how-to-access-file-geodatabase-in-qgis
Thank you, Michael.
That's why I said 'yet'... I actually have that link saved as bookmark, but when I needed to access .GDB for a strict deadline, I ended up just installing ArcGIS trial. Maybe I'll make time for that QGIS procedure after my trial stops working. :angel:
Cheers
« Last Edit: September 25, 2014, 02:48:02 PM by BlackBox »
alanjt
  • Standby for witty remark...
All the more reason to upgrade to 2015.
I am curious, when you bring in a SHP file using mapwspace, you are able to isolate specific data with a polygon, but is it then possible to export that data out to a new shp file?
Dropbox
BlackBox
I tend to bring in .SHP using MAPIMPORT instead, and only opt for MAPWSPACE if I'm going to modify imported contour (imported as closed polygons with OD), or extract drainage basin data, etc.
I could be mistaken, as I do not often export to .SHP, but I suspect one can export to .SHP so long as the entities selected are valid types supported by .SHP (if that makes sense).
Cheers
Actually still no compelling reason to upgrade to 2015 (still no use of Google Earth data)
And you find better results NOT using MAPWSAPCE>>Data Connect to wok with your SHP files.
Rather use MAPIMPORT - be sure to use Import Closed  Shapes as Polygons function or you get hatched areas instead of boundaries
BlackBox
... still no use of Google Earth data
I thought the new Google Earth API exposed that ability (not natively, albeit), no?
sure, but that isn't the same as native support, because Autodesk wants to be pigheaded about paying a license fee to Google.
BlackBox
I noted that already, and do not disagree with your assessment... One can make use of Google Earth data though, is the point. :angel:
Cheers
[Edit] - You've probably seen this already, as example.
Cheers
I still stand by my assessment that there is no compelling reason to use 2015 release.  Not really enough NEW and or IMPROVED to justify installation.
BlackBox
Cheers
:-D
