Author Topic: DCL - Making button default  (Read 2819 times)
« on: April 15, 2005, 02:49:44 PM »
I would like to make the "ok" button default so when i hit enter the dialog goes away.  (Im horrible at DCL)
ibox : dialog {
    key = "title";
    : edit_box {
    key = "eb1";
    ok_cancel;
Any help would be appreciated.
« Reply #1 on: April 15, 2005, 03:40:51 PM »
is_default = true;
  • Custom Title
« Reply #2 on: April 15, 2005, 03:43:29 PM »
I was thinking allow_accept = true-false;
  • Custom Title
« Reply #3 on: April 15, 2005, 03:44:34 PM »
RTFM ............. :)
Programmable Dialog Box Reference
« Reply #4 on: April 15, 2005, 05:50:49 PM »
I think this is the sort of thing you're looking for :
My understanding is the allow_accept will only work if the control it is located in has focus when ENTER is pressed
texteditor : dialog {
    label = "Edit Text";
    initial_focus = "text_edit";
    : edit_box {
       label = "Text:";
       key = "text_edit";
       edit_width = 100;
       edit_limit = 1536;
       allow_accept = true;
    ok_cancel;
« Reply #5 on: April 15, 2005, 09:37:09 PM »
Kerry, That looks like it will work perfectly.  Thanx man.  (Although the edit width is a bit big. :lol:)
Works awesome! Thanx Kerry.
« Reply #6 on: April 15, 2005, 10:52:17 PM »
Nice one Kerry.
Here is another way: http://www.theswamp.org/phpBB2/viewtopic.php?t=2715
