Author Topic: how to get insert point of block based on a number associated with it  (Read 2663 times)
0 Members and 3 Guests are viewing this topic.
andrew_nao
attached is a sample BOM and a pic if you dont want to download the sample.
im attempting to get the insert point of the bmline (name of the block) based on the item number associated with it.
for example: when prompted, i type in "item 1" it would give me the insert point of the bmline that is associated with item #1 so i can do my thing.
i started to use following code, but it only gives me the insert point of the last block inserted
  (setq elist
(entget
   (ssname (ssget "x" (list '(0 . "INSERT") '(2 . "bmline*")))
   0
  (setq ip (cdr (assoc 10 elist)))
maybe count all the blocks and count backwards, to get to the bmline i need?
appreciate any guidance
edit: the insert point would be the top right corner of the block (bmline)
Re: how to get insert point of block based on a number associated with it
« Reply #1 on: September 23, 2014, 01:45:24 PM »
It's a shame that the data is not in the form of attributes - the task would otherwise be very simple  :|
« Reply #2 on: September 23, 2014, 02:48:20 PM »
Here is my attempt:
(defun getbmiinsertion ( a / e i l m p q r s )
    (if (setq s
            (ssget "_X"
               '(   (-4 . "<OR")
                        (-4 . "<AND")
                            (0 . "TEXT")
                            (1 . "~*[~0-9]*")
                            (72 . 1)
                            (73 . 0)
                        (-4 . "AND>")
                        (-4 . "<AND")
                            (0 . "INSERT")
                            (2 . "BMLINE")
                        (-4 . "AND>")
                    (-4 . "OR>")
            (repeat (setq i (sslength s))
                (setq e (entget (ssname s (setq i (1- i)))))
                (if (= "INSERT" (cdr (assoc 0 e)))
                    (setq l (cons (list (cdr (assoc 10 e)) (cdr (assoc 5 e))) l))
                    (setq m (cons (list (cdr (assoc 11 e)) (cdr (assoc 1 e))) m))
            (foreach x m
                (if (vl-some '(lambda ( y ) (if (apply 'and (mapcar '<= (mapcar '- (car y) '(33.0 1.5)) (car x) (car y))) (setq p y))) l)
                    (if (setq q (assoc (cadr p) r))
                        (if (< (caar x) (caaddr q))
                            (setq r (subst (append (reverse p) x) q r))
                        (setq r (cons (append (reverse p) x) r))
            (caddr (assoc a (mapcar 'reverse r)))
Call with the item number, e.g.:
_$ (getbmiinsertion "2")
(98.625 63.5462 0.0)
« Reply #3 on: September 23, 2014, 03:58:12 PM »
Agreed.
HasanCAD
« Reply #4 on: September 24, 2014, 08:27:18 AM »
My 5 cent
Converted to blocks
RC
« Reply #5 on: September 24, 2014, 01:41:14 PM »
Agreed.
Or embedded in xdata related to component data
andrew_nao
« Reply #6 on: September 24, 2014, 03:38:18 PM »
Here is my attempt:
    (if (setq s
            (ssget "_X"
               '(   (-4 . "<OR")
                        (-4 . "<AND")
                            (0 . "TEXT")
                            (1 . "~*[~0-9]*")
                            (72 . 1)
                            (73 . 0)
                        (-4 . "AND>")
                        (-4 . "<AND")
                            (0 . "INSERT")
                            (2 . "BMLINE")
                        (-4 . "AND>")
                    (-4 . "OR>")
            (foreach x m
works a charm. thank you
« Reply #7 on: September 24, 2014, 04:36:44 PM »
You're welcome  8-)
