Author Topic: Alignment Label in inches, but my units are in meters. HELP!!!  (Read 4397 times)
DPATTERSON
« on: September 23, 2014, 08:42:27 AM »
My alignment labels are in Inches and i cannot figure out how to change them my drawing units have been in decimal, meter, degrees the whole time so why are my labels all in Inches?  HELP!
Re: Alignment Label in inches, but my units are in meters. HELP!!!
« Reply #1 on: September 23, 2014, 08:58:14 AM »
All of them?
« Reply #2 on: September 23, 2014, 09:46:45 AM »
Just edit the styles
OR
Use Settings Label Style Default Overrides.....
common disconnect between
Drawing Settings _ Units and Zone
Ambient Settings
and
Label Styles - Units
DPATTERSON
« Reply #3 on: September 23, 2014, 01:58:35 PM »
I'm still learning the software could someone walk me through the process please.  :-)
« Reply #4 on: September 23, 2014, 05:16:12 PM »
You will need to go into label style composer for ALL labels and edit the text components to output your desired values.
huiz
  • Certified Prof C3D
« Reply #5 on: September 24, 2014, 04:16:08 AM »
And never start a new drawing with Imperial Template :-)
Unless you live in one of the three countries that still use the Imperial system.
« Reply #6 on: September 24, 2014, 08:59:56 AM »
Actually the Imperial template does NOT default to inches in the labels. (FEET yes inches NO)
« Reply #7 on: September 24, 2014, 09:25:52 AM »
How is this for a start?
Dinosaur
« Reply #8 on: September 24, 2014, 02:40:55 PM »
Am wondering if this was an existing drawing set up in regular AutoCAD just opened into Civil 3D.
DPATTERSON
« Reply #9 on: September 25, 2014, 10:47:53 AM »
Thank you Mark,
I have gotten as far as you have shown however I change it and it doesnt save it as meter just defaults back to feet.
« Reply #10 on: September 25, 2014, 10:51:48 AM »
you are not selecting the data in the right hand window - the black part of Mark's picture
then changing the units and clicking the WHITE arrow to insert the NEW code into the right hand panel
DPATTERSON
« Reply #11 on: October 03, 2014, 10:02:52 AM »
Thank you for all you help but it seemed to just be the file.  I tried over and over again to change the units but as soon as i did they would default back to feet.  I ended up creating a new drawing and copy over what i could and had no problems.
« Reply #12 on: October 03, 2014, 10:05:27 AM »
i would like to see that file - to identify
source of the issue
possible solutions
for future references
