Author Topic: Adding a Surface to Profile View.  (Read 8770 times)
DPATTERSON
« on: September 17, 2014, 11:57:30 AM »
Hello Everyone,
I am still learning so thank you for all your help.  I accidentally deleted the existing ground line in my profile and with it the elevation labels disappeared as well.  I am trying to add the existing surface back to the profile view so i can continue working but have not been able to figure out.
Your help is greatly appreciated!
Thank you in advance
-David
Re: Adding a Surface to Profile View.
« Reply #1 on: September 17, 2014, 12:40:49 PM »
David, it sounds like you are using Civil3D. Is that correct? If so, just create another EG profile for the alignment and it will automagically be added to the ProfileView.
For future reference, you should post questions regarding Civil3D in the LandLubbers group: http://www.theswamp.org/index.php?board=10.0
