Author Topic: ssget one layer, two different colors  (Read 2435 times)
cadman6735
« on: September 11, 2014, 12:22:56 PM »
LISP drives me crazy...
(defun c:test ( / )
  (setq ss (ssget "_x" (list (cons 8 "TESTLAYER") (cons -4 "<AND") (cons 62 4) (cons 62 6) (cons -4 "AND>"))))
  (sssetfirst nil ss)
I have put that ("<AND")("AND>") all over the map on this, I can't get it to work...
Can someone set me straight, Please
Re: ssget one layer, two different colors
« Reply #1 on: September 11, 2014, 12:27:14 PM »
Use OR
  1. (setq ss (ssget "_x" '((8 . "TESTLAYER") (-4 . "<OR") (62 . 4) (62 . 6) (-4 . "OR>"))))
Your code is looking for items that have two different colors which cannot happen.
« Last Edit: September 11, 2014, 12:35:51 PM by ronjonp »
dgorsman
« Reply #2 on: September 11, 2014, 12:33:49 PM »
Right.  As the original post stands, its trying for entities with (62 . 4) AND (62 . 6), which are mutually exclusive.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
cadman6735
« Reply #3 on: September 11, 2014, 12:46:40 PM »
see LISP drives me crazy,
the logic is wrong in my head, OR to me would be one "or" the other, (not both)
AND would indicate color 1 "and" color 2 (both together)
Anyway, RonJon, your ninja skill have helped me once again, thank you very much...
« Reply #4 on: September 11, 2014, 01:18:02 PM »
Just the way you phrase it.
I want apples AND they can be green OR red.
With ssget the AND is not needed most of the time as it is implied. :)
snownut2
  • Bricscad 22 Ultimate
« Reply #5 on: September 11, 2014, 01:22:00 PM »
Don't eat to many green ones though......
dgorsman
« Reply #6 on: September 11, 2014, 01:36:53 PM »
Standard Boolean logic.  An entity has only one color property - it can be RED or GREEN.  I cannot be RED and GREEN.  Apply the logic to the entities, not the filter settings.
try {GreatPower;}
   finally
      {MasterBasics;}
RGUS
« Reply #7 on: September 11, 2014, 02:28:45 PM »
Use OR
With the 'Sum over histories' and quantum mechanics it might. Just kidding... good solution here.
cadman6735
« Reply #8 on: September 11, 2014, 02:52:51 PM »
Thanks again guys, this site is one of the best for friendly and fast help.
« Last Edit: September 11, 2014, 02:55:55 PM by cadman6735 »
« Reply #9 on: September 13, 2014, 09:11:23 AM »
You're thinking of XOR (eXclusive OR)  :wink:
