Author Topic: save dwg as backup on open before its modified  (Read 5989 times)
Re: save dwg as backup on open before its modified
« Reply #15 on: September 11, 2014, 03:29:55 PM »
I was not sure how Andrew was going to implement the solution just throwing ideas out there. My backup saves files in 15 minute increments while working. Has worked well for me.
Then there was THIS lisp I wrote way back when that created a folder called 'SUPERSCEDE' and copied the current drawing and xrefs into it.
Have fun !
BlackBox
« Reply #16 on: September 11, 2014, 03:48:28 PM »
... and you will need to verify that the drawing is not a new drawing that has never been saved to disk.
Perhaps I've misunderstood the thread title, but the OP seems to be attempting to create a backup immediately after opening an existing drawing (not creating a new drawing).
My $0.02
You are correct, however, the solution was proposed to be added to the startup lisp ... the same startup lisp that runs regardless of whether you are opening a drawing or starting a new blank drawing ...
this is why I get paid the big bucks ;-)
Big bucks you may be paid, but where I previously state that need not be considered, you cannot cite. :angel:
« Reply #17 on: September 11, 2014, 03:52:04 PM »
My $0.02
WUT?
Who said anything about you? I was referring to the very first solution where it plainly says to add it to the startup. If you misunderstood, I cannot help that.
Matt__W
  • I like my water diluted.
« Reply #18 on: September 11, 2014, 03:56:45 PM »
Why not simply use Ron's code to make a copy each time the DWG is saved??  It's essentially the same as making a copy of it before it's modified, isn't it??  I mean, the file that is copied (whether it's after a save or before an open) is the same thing.
Autodesk Expert Elite
BlackBox
« Reply #19 on: September 11, 2014, 04:02:36 PM »
My $0.02
WUT?
You did. :wink:
alanjt
  • Standby for witty remark...
« Reply #20 on: September 11, 2014, 05:57:06 PM »
Here's a simple one I keep in my startup. If the file already exists (for the current day), it will not be copied over again, which is what I wanted.
I should change it to use a copy method other than vl-file-copy, just so I the original file edit date won't be changed, but it's never been a big deal for what this has been there for.
((lambda (/ path)
   (if (not (wcmatch (strcase (getvar 'DWGNAME)) "DRAWING*"))
       (vl-mkdir (setq path "c:\\dwgBackup"))
       (vl-mkdir (setq path (strcat path "\\" (menucmd "M=$(edtime,$(getvar,date),YYYY.M.DD)") "\\")))
       (vl-file-copy (strcat (getvar 'DWGPREFIX) (getvar 'DWGNAME)) (strcat path (getvar 'DWGNAME)))
Dropbox
BlackBox
« Reply #21 on: September 11, 2014, 06:49:59 PM »
I do something very similar in my VOID routine, which I used to make a dated copy of a drawing prior to making major design changes. I also have a routine which allows me to quickly 'step' through one or more previously created void copies (which are relative pathed).
Also, always good to see you in the forums AT. :beer:
« Reply #22 on: September 12, 2014, 12:03:55 PM »
My $0.02
WUT?
You did. :wink:
WUT? X2
« Reply #23 on: September 13, 2014, 09:27:35 AM »
FWIW, the above could be:
(if (= 1 (getvar 'dwgtitled))
To account for the possibility that a saved drawing starts with 'DRAWING...'
ChrisCarlson
« Reply #24 on: September 15, 2014, 08:29:14 AM »
Edited
« Last Edit: September 15, 2014, 01:15:02 PM by ChrisCarlson »
alanjt
« Reply #25 on: September 15, 2014, 08:38:25 AM »
I always forget about that variable. Thanks.
Granted, I seriously hope people aren't naming files starting with "Drawing".
Dropbox
andrew_nao
« Reply #26 on: September 15, 2014, 09:45:17 AM »
wow some good ideas in here.
the thought i was having was just to have a backup of a dwg like alajt's suggestion.
just 1 copy no overwrite, no delete and recopy. just 1 copy as "original".
that is very simple code too, i thought it would be a bit more complicated to implement.
appreciate everyones feedback
ChrisCarlson
« Reply #27 on: September 15, 2014, 01:18:38 PM »
Corrected the batch file
@ECHO OFF
SET _params=%*
CALL :sub "%_params%"
:sub
ECHO %~nx1
set folder=C:\AutoCAD_Originals
set odate=%date:~4,2%_%date:~7,2%_%date:~10,4%
copy %~nx1 "%FOLDER%\%~n1-%ODATE%.dwg"
start %~nx1
exit
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shell\Drawing Backup]
"Position"="Top"
"Extended"=""
[HKEY_CLASSES_ROOT\*\shell\Drawing Backup\command]
@="cmd.exe /T:17 /K C:\\AutoCAD_Originals "%1""
Simply right click and open the file you want with Drawing Backup.
Does time stamps matter? I know going through lisp changes the last edit time stamp within the file.
