Author Topic: Loaded Cui files  (Read 5990 times)
Latex
Loaded Cui files
« on: September 11, 2014, 10:42:31 AM »
Hello everyone,
I want to use a function letting me know if a partial cui file is loaded or not instead of loading it blindly.
I've found a way on that autodesk dev blog : http://through-the-interface.typepad.com/through_the_interface/2007/05/creating_a_part.html.
The only problem is that i am using C++ to do this program and Kean's sample code is in C#.
Therefore, I have some trouble making work this line.
string mainCui = Application.GetSystemVariable("MENUNAME") + ".cui";
CustomizationSection cs = new CustomizationSection(mainCui);
PartialCuiFileCollection pcfc = cs.PartialCuiFiles; // <- the incriminated line
My compiler doesnt seems to reach the PartialCuiFileCollection type ("candidate functions are not reachable").
So here is my question : is there any equivalent with C++ or anyone has encountered the same problem before?
Thanks a lot,
PS : Sorry for spelling mistakes.
owenwengerd
Re: Loaded Cui files
« Reply #1 on: September 11, 2014, 10:58:42 AM »
Are you using native C++ or managed C++? Which AutoCAD version are you targeting? Which ObjectARX SDK version are you using? Which version of Visual Studio?
Latex
« Reply #2 on: September 11, 2014, 11:08:14 AM »
Hello;
I am using managed C++ with Visual Studio 2010 Professional edition.
I am using object arx 2014 (64bits) for Autocad 2014.
I should have precised all of this, my bad.
Thanks,
Latex
« Reply #3 on: September 12, 2014, 06:16:30 AM »
Finally I've resolved my problem on my own, I had some big mess up with differents c++/cli types.
If that can help anyone having the same issue , here is my fix :
String^ mainCui = Autodesk::AutoCAD::ApplicationServices::Application::GetSystemVariable("MENUNAME")->ToString();
mainCui = mainCui + L".cuix";
Autodesk::AutoCAD::Customization::CustomizationSection^ cs = gcnew Autodesk::AutoCAD::Customization::CustomizationSection(mainCui);
Autodesk::AutoCAD::Customization::PartialCuiFileCollection^ pcfc = cs->PartialCuiFiles;
