Author Topic: Set plot configuration  (Read 9255 times)
Fabricio28
« on: September 11, 2014, 08:45:44 AM »
Hi guys,
I'm plotting many files and everytime when I open a file I have to set plot configuration.
I'd like to set a plot configuration as default.
Name: HP Color LaserJet 500
Paper size: A4
Plot offset: Center the plot
Plot scale: FIT to paper
Number of copies: 2
Thank in advande
Re: Set plot configuration
« Reply #1 on: September 11, 2014, 09:03:54 AM »
Make a pagesetup in a template and import it into the drawing on open using the following code.
  1. (defun _importpagesetups (template)
  2.     'vla-delete
  3.   )
  4.   (setvar 'filedia 0)
  5.   (if (findfile template)
  6.     (progn (vl-cmdf ".-psetupin" template "*") (princ "\n << Pagesetups Imported >>"))
  7.     (princ "\n << Pagesetups NOT FOUND! >>")
  8.   )
  9.   (setvar 'filedia 1)
  10.   (princ)
  11. )
  12. ;; (_importpagesetups "C:\\temp\\mytemplate.dwt)
BlackBox
« Reply #2 on: September 11, 2014, 09:05:56 AM »
Hi guys,
Paper size: A4
Number of copies: 2
Thank in advande
Create a named page setup in your drawing template, either at drawing open, or on command, import your named page setup (either via ODBX, or PSETUPIN Command), and use this to set as active for all applicable Layouts.
Example:
  1. (foreach layoutname (layoutlist)
  2.   (vla-SetActivePageSetup layoutname <YourPageSetupName>)
  3. )
  4.
Cheers
[Edit] - D@mn ninja's fast.  :-D
[Edit[ - Looks like AUGI's down; here's a cached version of the linked post above.
« Last Edit: September 11, 2014, 09:18:56 AM by BlackBox »
Rob...
« Reply #3 on: September 11, 2014, 09:17:30 AM »
Named page set-ups can be imported into the layouts from other files.
They can be temporarily applied for plotting using publisher.
They can also be applied using Project Navigator.
CAD Tech
« Reply #4 on: September 11, 2014, 09:26:34 AM »
BlackBox
« Reply #5 on: September 11, 2014, 09:28:52 AM »
[Edit] - D@mn ninja's fast.  ;D
You're soooo going to see the new TMNT movie; aren't you?
Fabricio28
« Reply #6 on: September 11, 2014, 09:34:18 AM »
Thank for the quick replay guys,
Sorry but I can't doing that.
When I imported the pagesetup of my template, the number of copies continue 1 but I set 2 copies.
My current drawing is already set the plot area in windows and I'd like to keep it.
When I open my file, I have to set plotter name, number of copies and center the plot.
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: September 11, 2014, 09:40:54 AM »
Have you tried the "previous" under the pagesetup?  This will remember your settings from the previous plot during an open session of the application and set them current for the current plot.
« Reply #8 on: September 11, 2014, 09:41:02 AM »
Fabricio28
« Reply #9 on: September 11, 2014, 09:44:25 AM »
Yes, but the number of copies still 1 and I'd like to set for 2 copies.
Regards
BlackBox
« Reply #10 on: September 11, 2014, 09:48:13 AM »
« Reply #11 on: September 11, 2014, 09:51:47 AM »
Regards
From my quick test, the number of copies is not saved to the layout. Maybe another route ... print it twice? :)
Fabricio28
« Reply #12 on: September 11, 2014, 09:58:36 AM »
Regards
Yes, Ron. Save my previous plot and print it twice.
« Reply #13 on: September 11, 2014, 09:58:55 AM »
Give this a try .. does not set the number of plots but should do the rest.
  1.   (if (> (vla-get-taborder l) 0)
  2.     (progn (vla-put-configname l "HP Color LaserJet 500")
  3.            (vla-put-canonicalmedianame l "A4")
  4.            (vla-put-centerplot l :vlax-true)
  5.            (vla-put-standardscale l acvpscaletofit)
  6.     )
  7.   )
  8. )
« Last Edit: September 11, 2014, 10:12:49 AM by ronjonp »
Fabricio28
« Reply #14 on: September 11, 2014, 10:05:21 AM »
ron,
It's to be load just like a lisp?
give me a error
Automation Error. Invalid input
I installed a new plotter and the autocad isn't recognizing.
« Last Edit: September 11, 2014, 10:11:25 AM by FABRICIO28 »
