Author Topic: LogonUser and mediaelement  (Read 1450 times)
dawido000
« on: September 07, 2014, 02:03:00 AM »
When I use Logonuser function to log on share folder in another computer in local network, I can copy .avi file from this folder, but I can not to make it play in mediaElement. Why? Nothing is happening, there is no any communicate.
Below my code:
public partial class MainWindow : Window
        DispatcherTimer timer;
        SoddingNetworkAuth SNA;
        public MainWindow()
            InitializeComponent();
            timer = new DispatcherTimer();
            timer.Interval = TimeSpan.FromMilliseconds(500);
            timer.Tick += new EventHandler(timer_Tick);
        void timer_Tick(object sender, EventArgs e)
            slider1.Value = mediaElement1.Position.TotalSeconds;
        private void button1_Click(object sender, RoutedEventArgs e)
            string[] files;
            bool bJestDostep = true;
            SNA = new SoddingNetworkAuth(@"admin", @"kp", @"asd21247");
                try
                    files = Directory.GetFiles(@"\\kp\Instalki\Lekcje");
                catch
                    bJestDostep = false;
                if (bJestDostep)
                    string strNazwaPliku = ((ListBoxItem)listBox1.SelectedValue).Content.ToString();
                    mediaElement1.Source = new Uri(@"\\kp\Instalki\Lekcje\" + strNazwaPliku + ".avi", UriKind.Absolute);
                    mediaElement1.LoadedBehavior = MediaState.Manual;
                    mediaElement1.UnloadedBehavior = MediaState.Manual;
                    mediaElement1.Play();
        //Play button
        private void button2_Click(object sender, RoutedEventArgs e)
        private void slider1_ValueChanged(object sender, RoutedPropertyChangedEventArgs<double> e)
            mediaElement1.Position = TimeSpan.FromSeconds(slider1.Value);
        private void mediaElement1_MediaOpened(object sender, RoutedEventArgs e)
            TimeSpan ts = mediaElement1.NaturalDuration.TimeSpan;
            slider1.Maximum = ts.TotalSeconds;
            timer.Start();
        private void button3_Click(object sender, RoutedEventArgs e)
            SNA.Dispose();
            mediaElement1.Pause();
    public class SoddingNetworkAuth
        [DllImport("advapi32.dll", SetLastError=true)]
        private static extern bool LogonUser(string lpszUsername, string lpszDomain, string lpszPassword, int dwLogonType, int dwLogonProvider, out IntPtr phToken);
        [DllImport("kernel32", SetLastError = true )]
        private static extern bool CloseHandle(IntPtr hObject);
        private IntPtr userHandle = IntPtr.Zero;
        private WindowsImpersonationContext impersonationContext;
        //konstruktor
        public SoddingNetworkAuth(string user, string domain, string password)
            if ( !string.IsNullOrEmpty( user ) )
                // Call LogonUser to get a token for the user
                bool loggedOn = LogonUser( user, domain, password,
                                9 /*(int)LogonType.LOGON32_LOGON_NEW_CREDENTIALS*/,
                                0 /*(int)LogonProvider.LOGON32_PROVIDER_WINNT50*/,
                                out userHandle );
                if ( !loggedOn )
                    throw new Win32Exception( Marshal.GetLastWin32Error() );
                // Begin impersonating the user
                impersonationContext = WindowsIdentity.Impersonate( userHandle );
        public void Dispose()
            if (userHandle != IntPtr.Zero)
                CloseHandle(userHandle);
            if ( impersonationContext != null )
                impersonationContext.Undo();
