Author Topic: 1/2" DB Bolt...F1  (Read 4879 times)
T-Square
1/2" DB Bolt...F1
« on: September 05, 2014, 01:59:36 PM »
Hello,
I know I know...someone can do it better. :-) So be it....
See attached. Problem I am having is the "Custom" string I had a while back in the "Block Properties Table"... I can't seem to find a way of removing it.
Does anyone know how to remove the "Custom" string so that it's not there and does not show up in the Properties manager?
Thanks in advance.
Re: 1/2" DB Bolt...F1
« Reply #1 on: September 05, 2014, 03:06:42 PM »
When I open that drawing I don't see a block properties table ?
T-Square
« Reply #2 on: September 05, 2014, 03:22:26 PM »
You won't see it until you bring up the properties manager. If you add a block properties table to the drawing, then you can see it as the "string" in the "Block properties table". I added it earlier on in the creation of this, but then decided not to use it, but I can't figure out how to remove it.
« Reply #3 on: September 05, 2014, 03:39:00 PM »
Give this one a try. I wblocked the drawing over itself and it fixed it.  :)
« Reply #4 on: September 05, 2014, 04:30:46 PM »
Glad to help  :)
