Not that I know of.
Were you able to open the DWG I converted??
Quote from: M@yhem on September 02, 2014, 02:18:38 PMWere you able to open the DWG I converted??If the file has already been saved down, your conversion still won't work.
SAVE AS and AECTOACAD are two different commands. Save As does just that.... saves the current drawing as a different version. AECTOACAD strips all of the AEC info from the drawing and converts it to basic AutoCAD entities.
I noticed the OLE object but didn't give it much thought since it wasn't linked to an external file and you could see it whereas with the PDF you couldn't see it. stupid OLE objects... *shakes fist at the OLE gods*
