Author Topic: Change Z value of point after using VLA-GetPoint  (Read 8310 times)
Re: Change Z value of point after using VLA-GetPoint
« Reply #15 on: August 22, 2014, 05:35:00 PM »
Using variants/safearrays:
  1. (defun c:test ( / *error* roundup8 list->variant doc hgt len lli llp lri lrp pl1 pl2 rg1 rg2 spc uli ulp uri urp wid )
  2.
  3.     (defun *error* ( msg )
  4.         (foreach obj (list pl1 pl2 rg1 rg2)
  5.             (if (and obj (vlax-write-enabled-p obj)) (vla-delete obj))
  6.         )
  7.         (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  8.             (princ (strcat "\nError: " msg))
  9.         )
  10.         (princ)
  11.     )
  12.
  13.     (defun roundup8 ( n / r )
  14.         (setq r (rem n 8))
  15.         (if (or (equal 0.0 r 1e-8) (equal 8.0 r 1e-8)) (atof (rtos n 2 0)) (+ n (- 8 r)))
  16.     )
  17.
  18.     (defun list->variant ( typ lst )
  19.         (vlax-make-variant
  20.             (vlax-safearray-fill
  21.                 (vlax-make-safearray typ (cons 0 (1- (length lst))))
  22.                 lst
  23.             )
  24.         )
  25.     )
  26.
  27.           spc (vla-get-modelspace doc)
  28.     )
  29.     (initget 6)
  30.     (if (setq len (getdist "\nEnter wall length: "))
  31.         (progn
  32.             (setq len (roundup8 (* len 12.0)))
  33.             (initget 6)
  34.             (if (setq wid (getdist "\nEnter wall width: "))
  35.                 (progn
  36.                     (setq wid (roundup8 (* wid 12.0)))
  37.                     (initget 6)
  38.                     (if (setq hgt (getdist "\nEnter wall height: "))
  39.                         (progn
  40.                             (setq hgt (roundup8 (* hgt 12.0)))
  41.                             (if (setq ulp (getpoint "\nPick upper-left wall corner: "))
  42.                                 (progn
  43.                                     (setq ulp (list (car ulp) (cadr ulp))
  44.                                           lrp (mapcar '+ ulp  (list len (- wid)))
  45.                                           uli (mapcar '+ ulp '( 8 -8))
  46.                                           lri (mapcar '+ lrp '(-8  8))
  47.                                           urp (list (car lrp) (cadr ulp))
  48.                                           llp (list (car ulp) (cadr lrp))
  49.                                           uri (list (car lri) (cadr uli))
  50.                                           lli (list (car uli) (cadr lri))
  51.                                           pl1 (vla-addlightweightpolyline spc (list->variant vlax-vbdouble (append ulp urp lrp llp)))
  52.                                           pl2 (vla-addlightweightpolyline spc (list->variant vlax-vbdouble (append uli uri lri lli)))
  53.                                     )
  54.                                     (vla-put-closed pl1 :vlax-true)
  55.                                     (vla-put-closed pl2 :vlax-true)
  56.                                     (setq rg1 (car (vlax-safearray->list (vlax-variant-value (vla-addregion spc (list->variant vlax-vbobject (list pl1))))))
  57.                                           rg2 (car (vlax-safearray->list (vlax-variant-value (vla-addregion spc (list->variant vlax-vbobject (list pl2))))))
  58.                                     )
  59.                                     (vla-delete pl1)
  60.                                     (vla-delete pl2)
  61.                                     (vla-boolean rg1 acsubtraction rg2)
  62.                                     (vla-addextrudedsolid spc rg1 hgt 0.0)
  63.                                     (vla-delete rg1)
  64.                                 )
  65.                             )
  66.                         )
  67.                     )
  68.                 )
  69.             )
  70.         )
  71.     )
  72.     (princ)
  73. )
« Last Edit: August 22, 2014, 06:16:50 PM by Lee Mac »
« Reply #16 on: August 22, 2014, 06:01:16 PM »
Here's another quick example for a general wall outline:
  1. (defun c:wall ( / *error* ent hgt obj off pt1 rg1 rg2 spc thk )
  2.
  4.         (foreach obj (vl-list* obj rg1 (append rg2 off))
  6.                 (vla-delete obj)
  7.             )
  8.         )
  9.         (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
  10.             (princ (strcat "\nError: " msg))
  11.         )
  12.         (princ)
  13.     )
  14.
  15.     (setq thk 8.0) ;; Wall thickness
  16.
  17.     (if (setq pt1 (getpoint "\nPick start point: "))
  18.         (progn
  19.             (setq spc (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
  20.                   ent (entlast)
  21.             )
  22.             (vl-cmdf "_.pline" "_non" pt1)
  23.             (while (= 1 (logand 1 (getvar 'cmdactive))) (vl-cmdf "\\"))
  24.             (if (and (not (eq ent (setq ent (entlast))))
  25.                      (= "AcDbPolyline" (vla-get-objectname (setq obj (vlax-ename->vla-object ent))))
  26.                      (progn
  27.                          (vla-put-closed obj :vlax-true)
  28.                          (initget 6)
  29.                          (setq hgt (getdist "\nSpecify wall height: "))
  30.                      )
  31.                 )
  32.                 (progn
  33.                     (if (not (LM:listclockwise-p (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) (entget ent)))))
  34.                         (setq thk (- thk))
  35.                     )
  36.                     (if (setq off (LM:catchapply 'vlax-invoke (list obj 'offset thk)))
  37.                         (if (setq rg1 (car (LM:catchapply 'vlax-invoke (list spc 'addregion (list obj)))))
  38.                             (if (setq rg2 (LM:catchapply 'vlax-invoke (list spc 'addregion off)))
  39.                                 (progn
  40.                                     (foreach reg rg2 (vla-boolean rg1 acsubtraction reg))
  41.                                     (vla-addextrudedsolid spc rg1 hgt 0.0)
  42.                                 )
  43.                                 (princ "\nUnable to create internal region.")
  44.                             )
  45.                             (princ "\nUnable to create external region.")
  46.                         )
  47.                         (princ "\nWall outline too small for wall thickness.")
  48.                     )
  49.                 )
  50.             )
  51.         )
  52.     )
  53.     (*error* nil) (princ)
  54. )
  55.
  56. ;; List Clockwise-p  -  Lee Mac
  57. ;; Returns T if the point list is clockwise oriented
  58.
  59. (defun LM:ListClockwise-p ( lst )
  60.     (minusp
  61.         (apply '+
  62.             (mapcar
  63.                 (function
  64.                     (lambda ( a b )
  65.                         (- (* (car b) (cadr a)) (* (car a) (cadr b)))
  66.                     )
  67.                 )
  68.                 lst (cons (last lst) lst)
  69.             )
  70.         )
  71.     )
  72. )
  73.
  74. ;; Catch Apply  -  Lee Mac
  75. ;; Applies a function to a list of parameters and catches any exceptions.
  76.
  77. (defun LM:catchapply ( fnc prm / rtn )
  78.     (if (not (vl-catch-all-error-p (setq rtn (vl-catch-all-apply fnc prm))))
  79.         rtn
  80.     )
  81. )
  82.
  83. ;; Active Document  -  Lee Mac
  84. ;; Returns the VLA Active Document Object
  85.
  86. (defun LM:acdoc nil
  87.     (LM:acdoc)
  88. )
Quick demo:
David Hall
  • Automatic Duh Generator
« Reply #17 on: August 22, 2014, 06:09:11 PM »
OMG, I can now see why I was having so much trouble.  I like your first method much better.  Thanks Lee, your awesome!!!
« Reply #18 on: August 22, 2014, 06:18:03 PM »
Thanks David - I agree, its usually much easier to avoid variants/safearrays if possible.
ribarm
  • Marko Ribar, architect
« Reply #19 on: August 23, 2014, 02:37:54 AM »
@Lee, I would suggest that you use (initget 7) instead of (initget 6) to avoid nil result after user presses enter while (getdist)...
M.R. on Youtube
« Reply #20 on: August 23, 2014, 08:25:06 AM »
This is not necessary as the null input is accounted for by the various if statements; furthermore, if (initget 7) were to be used, the user would have no way of exiting the program without pressing Esc & forcing an error.
David Hall
« Reply #21 on: August 27, 2014, 01:54:34 PM »
Lee, using your code from above, I am trying to cut a hole in the wall.  I have gotten this far
  1. (defun DRAW_GATE (/ *ERROR* ROUNDUP8 DOC SPC LEN REFCORNER)
  2.   (defun *ERROR* (MSG)
  3.     (foreach OBJ (list PL1 PL2 RG1 RG2)
  4.       (if (and OBJ (vlax-write-enabled-p OBJ))
  5.    (vla-delete OBJ)
  6.       )
  7.     )
  8.     (if   (not (wcmatch (strcase MSG t) "*break,*cancel*,*exit*"))
  9.       (princ (strcat "\nError: " MSG))
  10.     )
  11.     (princ)
  12.   )
  13.
  14.   (defun ROUNDUP8 (N / R)
  15.     (setq R (rem N)
  16.     (if   (or (equal 0.0 R 1e-8) (equal 8.0 R 1e-8))
  17.       (atof (rtos N 2 0))
  18.       (+ N (- 8 R))
  19.     )
  20.   )
  21.    SPC (vla-get-modelspace DOC)
  22.   )
  23.
  24.   (initget 6)
  25.   (if (setq LEN (getdist "\nEnter Distance from corner >= 15.333: "))
  26.     (progn
  27.       (setq LEN (ROUNDUP8 (* LEN 12.0)))
  28.       (if (setq REFCORNER (getpoint "\nPick reference corner: "))
  29.    (progn
  30.      (if (setq
  31.       REFANGLE (getangle REFCORNER
  32.                "\nPick reference point on wall: "
  33.           )
  34.          )
  35.        (setq INSPT       (polar REFCORNER REFANGLE LEN)
  36.         BOX       (vlax-invoke SPC 'ADDBOX INSPT 240 240 360)
  37.         SEL       (ssget '((0 . "3DSOLID")))
  38.         WALL       (car (entget (ssname SEL 0)))
  39.         WALLPIECE (vla-boolean WALL acsubtraction BOX)
  40.
  41.        )
  42.
  43.
  44.      )
  45.    )
  46.       )
  47.     )
  48.   )
  49. )
but it errors out after creating the box.
Any Ideas?
Also, from code above, you set rg1 equal to the region created using car, when I try the same, it errors.
Also it should be noted that the error function needs updating, but I'm not quite sure what you were doing, so I haven't tried to change it yet.
David Hall
« Reply #22 on: August 27, 2014, 06:04:59 PM »
I was able to ake this work
;;;   SEL     (ssget '((0 . "3DSOLID")))
  WALL      (car (entsel "\nPick wall: "))
  wall (vlax-ename->vla-object wall)
;;;   (vla-boolean WALL acintersection BOX)
  WALLPIECE (vla-boolean wall acsubtraction box)
but I thought that the acintersection created a new piece of 3dsolid, not erase everything but the intersection
« Reply #23 on: August 27, 2014, 06:41:04 PM »
I was about to suggest converting the entity to a vla-object before issuing the boolean method, but it looks like you've got it  :-)
Yes, the acintersection operation will return only the intersection of the two solids.
