Author Topic: =={challenge}== Programmer Test - Fizz/Buzz  (Read 12949 times)
0 Members and 3 Guests are viewing this topic.
Re: =={challenge}== Programmer Test - Fizz/Buzz
« Reply #15 on: August 21, 2014, 10:51:25 PM »
Stefan,
ph:FB5 is faster than I'd anticipated. I thought the nth would slow it down a little.
Well done !!
« Reply #16 on: August 21, 2014, 11:02:03 PM »
I'd be interested to see how the various attempts benchmark when utilizing any two random divisors
Something like this:
  1. (defun fb (n d1 d2)
  2.   (nth (logior (min (rem n d1) 1) (lsh (min (rem n d2) 1) 1))
  3.        (list "FizzBuzz" "Buzz" "Fizz" n)
  4.   )
  5. )
« Reply #17 on: August 22, 2014, 04:30:07 AM »
Javascript in Chrome Console API
Code - Javascript: [Select]
  1. for (i = 0; i < 30;)console.log((++i % 3 ? '' : 'Fizz') + (i % 5 ? '' : 'Buzz') || i)
  2.
Difficult to get it any tighter than this I think.
« Reply #18 on: August 22, 2014, 04:51:18 AM »
And some C# options
courtesy of stackoverflow :)
Code - C#: [Select]
  1. using System;
  2.
  3. namespace FizzyButt
  4. {
  5.     internal class Program
  6.     {
  7.         private static void Main(string[] args)
  8.         {
  9.             FizzyButt01();
  10.             FizzyButt02();
  11.         }
  12.
  13.         public static void FizzyButt01()
  14.         {
  15.             for (int i = 1; i <= 30; i++)
  16.             {
  17.                 bool fizz = i%3 == 0;
  18.                 bool buzz = i%5 == 0;
  19.                 if (fizz && buzz) {Console.WriteLine("FizzBuzz");}
  20.                 else if (fizz)    {Console.WriteLine("Fizz");}
  21.                 else if (buzz)    {Console.WriteLine("Buzz");}
  22.                 else              {Console.WriteLine(i);}
  23.             }
  24.         }
  25.
  26.         public static void FizzyButt02()
  27.         {
  28.             for (int i = 1; i < 31; i++)
  29.             {
  30.                 Console.WriteLine(
  31.                                   "{0:#;}{1:;;Fizz}{2:;;Buzz}",
  32.                                   i%3*i%5 == 0 ? 0 : i,
  33.                                   i%3,
  34.                                   i%5);
  35.             }
  36.         }
  37.     }
  38. }
  39.
« Reply #19 on: August 22, 2014, 05:17:06 AM »
This will probably keep any propellerheads happy over the weekend :-D
http://rosettacode.org/wiki/FizzBuzz
piccy stolen from www.propellerhead.com.au
« Reply #20 on: August 22, 2014, 05:20:41 AM »
Powershell:
Code - PowerShell: [Select]
  1. function fizzbuzz ( $n )
  2. {
  3.     if (($f = ($n%3 -eq 0)) -and ($b = ($n%5 -eq 0))) { write-host 'FizzBuzz' }
  4.     else
  5.     {
  6.         if ($f) { write-host 'Fizz' }
  7.         else
  8.         {
  9.             if ($b) { write-host 'Buzz' }
  10.             else
  11.             {
  12.                 write-host $n
  13.             }
  14.         }
  15.     }
  16. }
  17.
  18. (1..30) | % {fizzbuzz $_}
EDIT: Oops - forget elseif was available in PowerShell :oops:
Though, the PowerShell code on Rosetta could be shortened slightly to:
  1. 1..100 | % {
  2.     if ($_ % 15 -eq 0) {
  3.         "FizzBuzz"
  4.     } elseif ($_ % 5 -eq 0) {
  5.         "Buzz"
  6.     } elseif ($_ % 3 -eq 0) {
  7.         "Fizz"
  8.     } else {
  9.         $_
  10.     }
  11. }
« Last Edit: August 22, 2014, 05:32:19 AM by Lee Mac »
« Reply #21 on: August 22, 2014, 06:19:32 AM »
  1. (defun ph:FB5 (n)
  2.   (cond
  3.     ((nth (rem n 15) '("FizzBuzz" nil nil "Fizz" nil "Buzz" "Fizz" nil nil "Fizz" "Buzz" nil "Fizz" nil nil)))
  4.     (n)
  5.     )
  6.   )
Another couple of variations of this method:
  1. (defun fizzbuzz ( n )
  2.     (cond ((nth (gcd n 15) '(nil nil nil "Fizz" nil "Buzz" nil nil nil nil nil nil nil nil nil "FizzBuzz"))) (n))
  3. )
  2.     (nth (gcd n 15) (list nil n nil "Fizz" nil "Buzz" nil nil nil nil nil nil nil nil nil "FizzBuzz"))
  3. )
  1. (defun fizzbuzz ( n / g )
  2.     (if (= 1 (setq g (gcd n 15))) n (nth (/ g 5) '("Fizz" "Buzz" nil "FizzBuzz")))
  3. )
« Last Edit: August 22, 2014, 06:23:23 AM by Lee Mac »
Stefan
« Reply #22 on: August 22, 2014, 06:35:32 AM »
Something stolen from rosettacode.org (the gcd thing)
  1. (defun ph:fb8 (n / r)
  2.   (cond
  3.     ((=  3 (setq r (gcd 15 n))) "Fizz")
  4.     ((=  5 r) "Buzz")
  5.     ((= 15 r) "FizzBuzz")
  6.     (n)
  7.   )
  8. )
And a variant
  1. (defun ph:fb9 (n)
  2.   (or *lst2* (setq *lst2* '((3 . "Fizz") (5 . "Buzz") (15 . "FizzBuzz"))))
  3.   (cond
  4.     ((cdr (assoc (gcd 15 n) *lst2*)))
  5.     (n)
  6.   )
  7. )
« Reply #23 on: August 22, 2014, 11:50:28 AM »
I considered using assoc, but thought it may be slow given the benchmark of my earlier function...  :|
pBe
« Reply #24 on: August 23, 2014, 11:27:40 PM »
a different approach to add to the table  ;D
(Defun _fizzybuzzy (n / _n n_ nl _3 _5)
  (setq   n_ n
   _n (vl-string->list (itoa n))
  (Setq   _5 (or (= (setq nl (last _n)) 48)
          (= nl 53)
    ((and (setq   _3 (= (Setq n
              (/ (apply '+ (mapcar '(lambda (m) (- m 48)) _n)) 3.0)
            (fix n)
     _5
     "FizzBuzz"
    (_3 "Fizz")
    (_5 "Buzz")
    (T n_)
EDIT: Bummer, there's something wrong with the Math.. hang on. editing.....
Code modified
« Last Edit: August 24, 2014, 12:36:23 AM by pBe »
gile
  • Marseille, France
« Reply #25 on: August 24, 2014, 05:52:23 AM »
My F# attempt (written before reading Kerry's link)
Code - F#: [Select]
  1. let fizzBuzz n =
  2.     match n % 3, n % 5 with
  3.     | 0, 0 -> "FizzBuzz"
  4.     | 0, _ -> "Fizz"
  5.     | _, 0 -> "Buzz"
  6.     | _ -> string n
  7.
  8. [1 .. 30] |> List.map fizzBuzz
This is very closed to the following LISP code:
  1. (defun fizzBuzz (n / l)
  2.   (setq l (list (rem n 3) (rem n 5)))
  3.   (cond
  4.     ((equal l '(0 0)) "FizzBuzz")
  5.     ((zerop (car l)) "Fizz")
  6.     ((zerop (cadr l)) "Buzz")
  7.     (T (itoa n))
  8.   )
  9. )
  10.
  11. (mapcar 'fizzBuzz  '(1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30))
You can try the F# code in Try F#
« Last Edit: August 24, 2014, 09:04:15 AM by gile »
Tharwat
  • Hypersensitive
« Reply #26 on: August 24, 2014, 06:25:04 AM »
This should be fast and unique  :-)
  1. (defun FizzBuzz (l)
  2.   (mapcar '(lambda (i)(if (zerop (rem i 15))    "FizzBuzz"
  3.                         (if (zerop (rem i 5))   "Buzz"
  4.                           (if (zerop (rem i 3)) "Fuzz"
  5.                             i)
  6.                           )
  7.                         )
  8.              )
  9.           l
  10.           )
  11.   )
  12.
irneb
« Reply #27 on: August 25, 2014, 05:00:37 AM »
So far it seems as if everyone's is passing the test! Great one guys! The level of programming here is obviously "better" than some other places! https://news.ycombinator.com/item?id=3354027
Makes me weep for the "future" of programming! And probably understand why we get so many bugs in our programs.
Anyhoo ... my first "obvious" attempt (i.e. literally following the description of the question):
  1. (defun IB:FizzBuzz (n)
  2.   (cond ((= (rem n 3) (rem n 5) 0) "FizzBuzz")
  3.         ((= (rem n 3) 0) "Fizz")
  4.         ((= (rem n 5) 0) "Buzz")
  5.         (n)))
Obviously very inefficient as it does at least 2 (on average nearly 4) division operations (which is one of the slowest CPU instructions you can give). I think that's why that benchmark shows such good results even for the nth version: nth is reasonably fast of short lists (which this definitely is).
So omitting one division (I think most of you got this one):
  1. (defun IB:FizzBuzz0 (n)
  2.   (cond ((= (rem n 15) 0) "FizzBuzz")
  5.         (n)))
Trying to reduce on the number of divisions and using assoc instead of nth ... ehhh ... don't truly know which "should" be better
  1. (defun IB:FizzBuzz1  (n)
  2.   (cond ((cdr (assoc (rem n 15) '((0 . "FizzBuzz") (3 . "Fizz") (5 . "Buzz") (6 . "Fizz")
  3.                                   (9 . "Fizz") (10 . "Buzz") (12 . "Fizz")))))
  4.         (n)))
And then rather using member instead
  1. (defun IB:FizzBuzz2 (n / r)
  2.   (cond ((= (setq r (rem n 15)) 0) "FizzBuzz")
  3.         ((member r '(3 6 9 12)) "Fizz")
  4.         ((member r '(5 10)) "Buzz")
  5.         (n)))
Of course the nth function would make it lots less circuitous. ... uh! ... scratch that my FizzBuzz3 is the exact same thing as ph:fb5 ... and I thought I got it so well!
I think none of mine is bringing anything "new" to the table. You guys already covered everything I had thought of myself, and then some!
Actually ... just though of another:
  1. (defun IB:FizzBuzz4 (n / L)
  2.   (if (setq L (vl-remove nil (mapcar '(lambda (d s) (cond ((= (rem n d) 0) s))) '(3 5) '("Fizz" "Buzz"))))
  3.     (apply 'strcat L)
  4.     n))
Sorry, it's probably been thought of by some of yourselves as well! Not that it's doing much different really - still performing 2 division operations and then all sorts of list manipulations, so speedwise I'd not hold my breath.
Anyhow, I've recently started looking into Haskell. Here's my first "very obvious" try (i.e. same as my FizzBuzz0 routine):
Code - Haskell: [Select]
  1. fizzBuzz :: Integer -> String
  2. fizzBuzz n | n `mod` 15 == 0 = "FizzBuzz"
  3.            | n `mod` 5  == 0 = "Fizz"
  4.            | n `mod` 3  == 0 = "Buzz"
  5.            | otherwise       = show n
Well ... not "exactly" the same since Haskell is static typed it's a bit difficult making a list with a mix of ints and strings like the Lisp does. I'm probably just not knowledgeable enough yet to get to the point fo doing it "properly" idiomatically! Definitely not to the degree in rosetacode, actually it's "exactly" the same as the 1st one there  :-o! I actually like that lazy infinite list approach ... wonder if it would be much faster since it never uses any divisions.
That drives me to wish we had lazy eval in AutoLisp ... another thing ADesk removed from the XLisp core they stole. I suppose one could simulate it by using a cached list, but it would be much less than optimal as it would need to grow at the end (not at the front, so either lots of reverses or lots of appends). Not to mention it would start degrading on larger numbers due to nth being a bit slow when the list is long.
« Last Edit: August 25, 2014, 05:16:36 AM by irneb »
Marc'Antonio Alessi
  • Marco
« Reply #28 on: August 25, 2014, 05:08:40 AM »
IMHO,
from my tests is the best version is Stefan's:
(defun ph:FB5 (n)
    ( (nth (rem n 15) '("FizzBuzz" nil nil "Fizz" nil "Buzz" "Fizz" nil nil "Fizz" "Buzz" nil "Fizz" nil nil)))
       (n)
originality 10
concision  10
speed      10
Last tests:
Benchmarking [M.P. 2005 < revised kdub 2005>] ...............
Elapsed milliseconds for 4096 iteration(s)/ relative Timing :
    (MAPCAR (QUOTE FIZZBUZZL2) FIZZLIST).....250 / 1.1416 <slowest>
    (MAPCAR (QUOTE FIZZBUZZL2) FIZZLIST).....249 / 1.137
    (MAPCAR (QUOTE PH:FB5) FIZZLIST).........234 / 1.0685
    (MAPCAR (QUOTE PH:FB5) FIZZLIST).........219 / 1 <fastest>
;Lee
 (defun fizzbuzzL2 ( n / g )
« Reply #29 on: August 25, 2014, 05:47:43 AM »
 :-o
Great challenge Irné - although relatively simple, I've enjoyed this thread  :-)
