Author Topic: "Possessed" multileaders  (Read 4011 times)
cadpoobah
« on: August 21, 2014, 10:33:33 AM »
I have a couple multileaders that are "possessed"!!!
In the attached drawing, there are two objects that look like just blocks. They are actually multileaders similar to EP-0 but without any leaders. (FWIW, they are used as "finish callouts" waiting for leaders to be added later.)
First, use the  COPY command on EP-2. Note two things: you don't see it "drag" as it's being copied (DRAGMODE is Auto) and it copies twice the distance as your pick points!  :-o (Similarly w the MOVE command.)
It gets weirder...
If you "add leaders" to "EP-1", you can recreate the look of EP-0 just fine. Try adding leader to "EP-2". Note the strange leader behavior.  :-o
And it gets weirder...
Now, UNDO the leader you just added to EP-2. The entire mulileader disappears, including the block content. But, if you do a select all, it select "6 objects", indicating that EP-2 is still in the drawing!  :-o
"You've just crossed over into the Twilight Zone"....
Would love to hear your thoughts.
Chris Lindner
Onebutton CAD Solutions
www.onebuttoncad.com #dayjob
www.unpavedart.com    #sidehustle
Re: "Possessed" multileaders
« Reply #1 on: August 21, 2014, 10:51:04 AM »
That is quite odd ...
« Reply #2 on: August 21, 2014, 11:31:46 AM »
it appears your EP2 is somehow 'nested'
an EXPLODE restores the drag visability and removes the weird scaling when copying issues
« Reply #3 on: August 21, 2014, 11:36:35 AM »
When you explode it loses the multileader and just  leaves the block definition. What is it "nested" in ?
« Reply #4 on: August 21, 2014, 11:42:21 AM »
Not quite sure - however creating a NEW mleader style and using that same block
presents none of the symptoms.
So without seeing what or how that one was made, I can only state;
it is 'somehow nested' .
This suggest that the solution is to KILL the current version a make a new one.
it works for me here.
Further the affected (infected) mleader style even hides the block attribute grips;
my new version exposes those attributes for editing.
« Reply #5 on: August 21, 2014, 11:51:06 AM »
Just did another test .. has something to do with the annotative scaling. If you turn it off then back on for the two problem multileaders it fixes them.
cadpoobah
« Reply #6 on: August 21, 2014, 01:49:23 PM »
Thanks, mjfarrell.
The attributed block (named "TDL_SYMB-ROOM") is the "Source block" for those multileaders. (For whatever reason, the originator didn't make a multileader style for this scenario.) All three of these multileaders are "built" same, but the one labeled "EP-2" behaves completely different from the others.
The problem is not with the block, its how AutoCAD handles attributes within a block within a multileader. Attributed blocks used within a multileader don't display the attribute's grips when the multileader is selected, unfortunately. It's a "feature"! :-)
Interesting find, ronjonp.
As stated, it seems that if you change the multileader from Annotative to non-Annotative then back to Annotative, it fixes all the problems associated with that leader; adding creates normal leaders, undoing doesn't get rid of the multileader, and COPY works correctly.
You, my friend, are the official "multileader exorcist"! :-)
Chris Lindner
« Reply #7 on: August 21, 2014, 01:58:51 PM »
cadpoobah
« Reply #8 on: August 21, 2014, 02:24:45 PM »
LOL!!!
Chris Lindner
