Author Topic: Run lsp from Visual Basic  (Read 2193 times)
josan
  • Mosquito
« on: August 23, 2014, 11:05:53 AM »
Good day.
Can I from Visual Basic Express 2010 create an application that will allow me to run AutoCAD and then load a *.lsp file and it runs?
thanks...
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: Run lsp from Visual Basic
« Reply #1 on: August 23, 2014, 04:28:34 PM »
dgorsman
« Reply #2 on: August 23, 2014, 11:06:58 PM »
I would advocate either building dotNET helper LISP functions or rebuilding the LISP code under dotNET.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
gile
  • Marseille, France
« Reply #3 on: August 24, 2014, 03:47:08 AM »
+1
Anyway, since AutoCAD 2011, you can use the Application.Invoke() .NET function (which wraps the acedInvoke() ObjectARX function) to call a LISP function from a .NET application and get its return value. The LISP function that is called must be previously-registered using the (vl-acad-defun) function or must have a C: prefix.
