Author Topic: question on the use of foreach  (Read 7011 times)
andrew_nao
« on: August 20, 2014, 04:48:00 PM »
when using foreach, do you need to use a (progn..) in there if you want to do more than 1 expression?
example would be:
  1. (foreach x lst
  2.    (progn
  3.       (do this)
  4.       (do this)
  5.       (do this)
  6.       (do this)
  7.       (do this)
  8.       (do this)
  9.     )
  10.  )
EDIT by Se7en: Fixed code tags, adjusted formatting slightly.
« Last Edit: August 21, 2014, 06:12:59 AM by John Kaul (Se7en) »
Re: question on the use of foreach
« Reply #1 on: August 20, 2014, 04:57:50 PM »
No.
As specified in the documentation:
Quote from: foreach documentation
The foreach function steps through a list, assigning each element in the list to a variable, and evaluates each expression for every element in the list. Any number of expressions can be specified.
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: August 20, 2014, 07:14:18 PM »
  1. (foreach x '(1 2 3 4 5 6)
  2.   (setq lst (append lst (list(1+ x))))
  3.   )
  4.
Will return  lst = (2 3 4 5 6 7)
« Reply #3 on: August 21, 2014, 06:36:48 AM »
Off topic reminder:
As a reminder to all, TheSwamp now has it's own Autolisp help which can be linked to (to use the example above) like this:
http://www.theswamp.org/~john/avlisp/#foreach
or to remove the url:
foreach
Also note that this help file can be added to or corrected by our members. If you want a section revised, please feel free to ask me or any of the moderators.
« Last Edit: August 21, 2014, 07:23:50 AM by Kerry »
« Reply #4 on: August 21, 2014, 07:25:23 AM »
Not only,  but also :: if we use the cadlisp-7 code tag
  1. (foreach thingystuff
  2.     select foreach or any blue highlighted stuff with the mouse using CLICK or CTRL-CLICK and watch the magic
  3. )
  4.
« Reply #5 on: August 21, 2014, 08:31:14 AM »
Yes, and that too. :)
On a side note: I know it's not the prettiest webpage but I did try to offer some helpful things when creating that help file. Like, I tried to keep the HTML to a minimum so it would be as quick (fast loading) as possible and wash out the colors a little to make it more "readable" (be more like a "paper white" and "ink type black").
This place is an amazing resource and I feel that everything we can do to separate ourselves from the pack of other Autodesk related help forums the better (we should continue to be the standard those other places strive to be like).
« Reply #6 on: August 21, 2014, 08:52:19 AM »
Yes, you've done a great job with it John.
The file is a couple of years out of date, so it probably needs a couple of hours of TLC ... but I can't make time to do it and I'm bloody sure you won't be able to either.
Perhaps one of the newer members will volunteer :-D
« Reply #7 on: August 21, 2014, 09:03:36 AM »
You are correct about that. I don't know what "free time" is anymore.
That is a wonderful idea! I hope someone volunteers.
andrew_nao
« Reply #8 on: August 21, 2014, 09:06:42 AM »
hmm.. i must be using it wrong.. thanks for the info
thanks for the format correction
« Reply #9 on: August 21, 2014, 09:15:26 AM »
Another option to remember ...
« Reply #10 on: August 21, 2014, 10:03:07 AM »
  3. )
  4.
Not sure why ... but those code tags have not worked for me in quite a while.  :?
« Reply #11 on: August 21, 2014, 10:09:26 AM »
  3. )
  4.
Which browser ron ?
What do you mean 'don't work' > can't set or can't see what others have set ?
I wonder if it's a JavaScript setting ?
« Reply #12 on: August 21, 2014, 10:30:10 AM »
Kerry,
I'm using Chrome. I can see when others use the tags, but they don't get added to my posts. I also get strangeness (height change \ added spaces \ font change) with formatting when using copy paste ... even paste without formatting ( ctrl+shift+v )
« Reply #13 on: August 21, 2014, 10:32:18 AM »
Here is a test post using Firefox. Autolisp tags still don't work ..... hhhhmmm
No added spaces to the post though .. got some wonkiness going on.
« Reply #14 on: August 21, 2014, 10:43:57 AM »
test post
  1.   ;-----------------------------------------
  2.   ; returns the x y point list of a caculated midpoint
  3.   ;
  4.   ; (midpt '(0.0 0.0 0.0) '(0.0 0.0 0.0) )
  5.   ;-----------------------------------------
  6.   (defun midpt (point_1 point_2)
  7.     (mapcar
  8.       '(lambda (x y) (/ (+ x y) 2.0)) point_1 point_2
  9.       )
  10.     )
  11.
chrome, windows 7
