Author Topic: question on the use of foreach  (Read 6954 times)
Re: question on the use of foreach
« Reply #15 on: August 21, 2014, 11:01:04 AM »
Test post Chrome Win 8.1
« Reply #16 on: August 21, 2014, 11:06:15 AM »
Here is a test post using Firefox. Autolisp tags still don't work ..... hhhhmmm
No added spaces to the post though .. got some wonkiness going on.
Weird!
The display you see (the forum/post) is just HTML with some java script for the dynamic stuff mixed in but you shouldn't have a problem viewing or typing (most forum boards aren't anything fancy or difficult for browsers to render).
For example, here is a snip of the code tag after GeSHi and SMF get done parsing the page.
Code - Text: [Select]
  1. <div class="list_posts smalltext" id="msg_526915_body">test post<br /><div class="codeheader">Code - Auto/Visual Lisp: <a href="javascript:void(0);" onclick="return smfSelectText(this);" class="codeoperation">[Select]</a></div><pre class="cadlisp-7 geshi" style="font-family:monospace;"><ol><li style=""><div style="font: normal normal 1em/1.2em monospace; margin:0; padding:0; background:none; vertical-align:top;"> &nbsp;<span style="color: #666666; font-style: italic;">;-----------------------------------------</span></div></li><li style=""><div style="font: normal normal 1em/1.2em monospace; margin:0; padding:0; background:none; vertical-align:top;"> &nbsp;<span style="color: #666666; font-style: italic;">; returns the x y point list of a caculated midpoint</span></div></li><li style=""><div style="font: normal normal 1em/1.2em monospace; margin:0; padding:0; background:none; vertical-align:top;">
« Reply #17 on: August 21, 2014, 11:07:52 AM »
I guess you'll have to just use the code tags and add "=cadlisp-7" to the opening tag. [ code=cadlisp-7 ]
« Reply #18 on: August 21, 2014, 11:12:20 AM »
Yup ... I'm going to do a test post from a Win 7 machine for $h!+$  :)
« Reply #19 on: August 21, 2014, 11:27:11 AM »
Same behavior with WinXP and Win7 maybe theme \ account related ?
andrew_nao
« Reply #20 on: August 21, 2014, 11:27:49 AM »
not me, win7 64 bit and it worked ok for me using chrome
« Reply #21 on: August 21, 2014, 11:34:34 AM »
Can you put the code tags in your post first then paste the text between them?
« Reply #22 on: August 21, 2014, 11:41:38 AM »
I can manually enter the tag, it just won't generate them.
« Reply #23 on: August 21, 2014, 01:12:25 PM »
to weird ....
« Reply #24 on: August 21, 2014, 01:38:01 PM »
What is weird is it can be reproduced on at least 4 different computers...
« Reply #25 on: August 21, 2014, 01:56:44 PM »
I truly don't understand; do you live in the Bermuda triangle or some other anomalous geographic location? ...I'm at a loss. Sorry.
« Reply #26 on: August 21, 2014, 02:03:08 PM »
Interesting .. just tested in IE11 *shudder* and it works fine  :? . Still no go in Firefox or Chrome.
« Reply #27 on: August 21, 2014, 02:04:41 PM »
lmao!
« Reply #28 on: August 21, 2014, 02:13:48 PM »
lmao!
 :2funny:
« Reply #29 on: August 21, 2014, 06:08:08 PM »
Ron,
Do you have JavaScript enabled on the Browsers ??
I use Win 7 Pro x64 , Chrome(latest)
