Author Topic: question on the use of foreach  (Read 6831 times)
andrew_nao
« on: August 20, 2014, 04:48:00 PM »
when using foreach, do you need to use a (progn..) in there if you want to do more than 1 expression?
example would be:
  1. (foreach x lst
  2.    (progn
  3.       (do this)
  4.       (do this)
  5.       (do this)
  6.       (do this)
  7.       (do this)
  8.       (do this)
  9.     )
  10.  )
EDIT by Se7en: Fixed code tags, adjusted formatting slightly.
« Last Edit: August 21, 2014, 06:12:59 AM by John Kaul (Se7en) »
Re: question on the use of foreach
« Reply #1 on: August 20, 2014, 04:57:50 PM »
No.
As specified in the documentation:
Quote from: foreach documentation
The foreach function steps through a list, assigning each element in the list to a variable, and evaluates each expression for every element in the list. Any number of expressions can be specified.
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: August 20, 2014, 07:14:18 PM »
  1. (foreach x '(1 2 3 4 5 6)
  2.   (setq lst (append lst (list(1+ x))))
  3.   )
  4.
Will return  lst = (2 3 4 5 6 7)
« Reply #3 on: August 21, 2014, 06:36:48 AM »
Off topic reminder:
As a reminder to all, TheSwamp now has it's own Autolisp help which can be linked to (to use the example above) like this:
http://www.theswamp.org/~john/avlisp/#foreach
or to remove the url:
foreach
Also note that this help file can be added to or corrected by our members. If you want a section revised, please feel free to ask me or any of the moderators.
« Last Edit: August 21, 2014, 07:23:50 AM by Kerry »
« Reply #4 on: August 21, 2014, 07:25:23 AM »
Not only,  but also :: if we use the cadlisp-7 code tag
  1. (foreach thingystuff
  2.     select foreach or any blue highlighted stuff with the mouse using CLICK or CTRL-CLICK and watch the magic
  3. )
  4.
« Reply #5 on: August 21, 2014, 08:31:14 AM »
Yes, and that too. :)
On a side note: I know it's not the prettiest webpage but I did try to offer some helpful things when creating that help file. Like, I tried to keep the HTML to a minimum so it would be as quick (fast loading) as possible and wash out the colors a little to make it more "readable" (be more like a "paper white" and "ink type black").
This place is an amazing resource and I feel that everything we can do to separate ourselves from the pack of other Autodesk related help forums the better (we should continue to be the standard those other places strive to be like).
« Reply #6 on: August 21, 2014, 08:52:19 AM »
Yes, you've done a great job with it John.
The file is a couple of years out of date, so it probably needs a couple of hours of TLC ... but I can't make time to do it and I'm bloody sure you won't be able to either.
Perhaps one of the newer members will volunteer :-D
« Reply #7 on: August 21, 2014, 09:03:36 AM »
You are correct about that. I don't know what "free time" is anymore.
That is a wonderful idea! I hope someone volunteers.
andrew_nao
« Reply #8 on: August 21, 2014, 09:06:42 AM »
hmm.. i must be using it wrong.. thanks for the info
thanks for the format correction
« Reply #9 on: August 21, 2014, 09:15:26 AM »
Another option to remember ...
« Reply #10 on: August 21, 2014, 10:03:07 AM »
  3. )
  4.
Not sure why ... but those code tags have not worked for me in quite a while.  :?
« Reply #11 on: August 21, 2014, 10:09:26 AM »
  3. )
  4.
Which browser ron ?
What do you mean 'don't work' > can't set or can't see what others have set ?
I wonder if it's a JavaScript setting ?
« Reply #12 on: August 21, 2014, 10:30:10 AM »
Kerry,
I'm using Chrome. I can see when others use the tags, but they don't get added to my posts. I also get strangeness (height change \ added spaces \ font change) with formatting when using copy paste ... even paste without formatting ( ctrl+shift+v )
« Reply #13 on: August 21, 2014, 10:32:18 AM »
Here is a test post using Firefox. Autolisp tags still don't work ..... hhhhmmm
No added spaces to the post though .. got some wonkiness going on.
  • Custom Title
« Reply #14 on: August 21, 2014, 10:43:57 AM »
test post
  1.   ;-----------------------------------------
  2.   ; returns the x y point list of a caculated midpoint
  3.   ;
  4.   ; (midpt '(0.0 0.0 0.0) '(0.0 0.0 0.0) )
  5.   ;-----------------------------------------
  6.   (defun midpt (point_1 point_2)
  7.     (mapcar
  8.       '(lambda (x y) (/ (+ x y) 2.0)) point_1 point_2
  9.       )
  10.     )
  11.
chrome, windows 7
« Reply #15 on: August 21, 2014, 11:01:04 AM »
Test post Chrome Win 8.1
« Reply #16 on: August 21, 2014, 11:06:15 AM »
Weird!
The display you see (the forum/post) is just HTML with some java script for the dynamic stuff mixed in but you shouldn't have a problem viewing or typing (most forum boards aren't anything fancy or difficult for browsers to render).
For example, here is a snip of the code tag after GeSHi and SMF get done parsing the page.
Code - Text: [Select]
  1. <div class="list_posts smalltext" id="msg_526915_body">test post<br /><div class="codeheader">Code - Auto/Visual Lisp: <a href="javascript:void(0);" onclick="return smfSelectText(this);" class="codeoperation">[Select]</a></div><pre class="cadlisp-7 geshi" style="font-family:monospace;"><ol><li style=""><div style="font: normal normal 1em/1.2em monospace; margin:0; padding:0; background:none; vertical-align:top;"> &nbsp;<span style="color: #666666; font-style: italic;">;-----------------------------------------</span></div></li><li style=""><div style="font: normal normal 1em/1.2em monospace; margin:0; padding:0; background:none; vertical-align:top;"> &nbsp;<span style="color: #666666; font-style: italic;">; returns the x y point list of a caculated midpoint</span></div></li><li style=""><div style="font: normal normal 1em/1.2em monospace; margin:0; padding:0; background:none; vertical-align:top;">
« Reply #17 on: August 21, 2014, 11:07:52 AM »
I guess you'll have to just use the code tags and add "=cadlisp-7" to the opening tag. [ code=cadlisp-7 ]
« Reply #18 on: August 21, 2014, 11:12:20 AM »
Yup ... I'm going to do a test post from a Win 7 machine for $h!+$  :)
« Reply #19 on: August 21, 2014, 11:27:11 AM »
Same behavior with WinXP and Win7 maybe theme \ account related ?
andrew_nao
« Reply #20 on: August 21, 2014, 11:27:49 AM »
not me, win7 64 bit and it worked ok for me using chrome
  • Custom Title
« Reply #21 on: August 21, 2014, 11:34:34 AM »
Can you put the code tags in your post first then paste the text between them?
« Reply #22 on: August 21, 2014, 11:41:38 AM »
I can manually enter the tag, it just won't generate them.
  • Custom Title
« Reply #23 on: August 21, 2014, 01:12:25 PM »
to weird ....
« Reply #24 on: August 21, 2014, 01:38:01 PM »
What is weird is it can be reproduced on at least 4 different computers...
« Reply #25 on: August 21, 2014, 01:56:44 PM »
I truly don't understand; do you live in the Bermuda triangle or some other anomalous geographic location? ...I'm at a loss. Sorry.
« Reply #26 on: August 21, 2014, 02:03:08 PM »
Interesting .. just tested in IE11 *shudder* and it works fine  :? . Still no go in Firefox or Chrome.
« Reply #27 on: August 21, 2014, 02:04:41 PM »
lmao!
« Reply #28 on: August 21, 2014, 02:13:48 PM »
lmao!
 :2funny:
« Reply #29 on: August 21, 2014, 06:08:08 PM »
Ron,
Do you have JavaScript enabled on the Browsers ??
I use Win 7 Pro x64 , Chrome(latest)
« Reply #30 on: August 21, 2014, 07:06:08 PM »
Yup.
