Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
VB(A)
Topic:
Inserting a block into an ACADTable
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Inserting a block into an ACADTable (Read 3253 times)
IBIEINIID
Guest
on:
August 15, 2014, 09:56:55 AM »
I'm writing an automator that fills a key with objects to label. I'd like to use a block with an attribute (attribute value will usually be a single letter) in the first column of each row and a part description in the second row. I'm ok with inserting the description text, but how might I insert a block into a table cell and edit its attribute? I imagine the SetBlockAttributeValue command would be to change the attribute, but I can't check that part until I can insert the block. Any help?
Logged
IBIEINIID
Guest
Re: Inserting a block into an ACADTable
Reply #1 on:
August 15, 2014, 09:58:48 AM »
Sorry, lemme correct that first sentence. I'm filling a table in AutoCAD with blocks in the first column, text in the second. Need to know how to insert blocks. If I just knew which ACADTable method to use, that'd probably solve my problem.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
VB(A)
Topic:
