Author Topic: as used command & command-s  (Read 12653 times)
TopoWAR
« on: August 11, 2014, 11:15:55 PM »
hi all, with the advent of autocad 2015 I've had enough problems with the use of: command, I had to apply this code to all routines, the question is: is there another way to avoid the mistakes ?
(if command-s (command-s "_layer" "_Thaw" "aaa" "") (command "_layer" "_Thaw" "aaa"""))
appreciate your help
Thanks for help
Tharwat
  • Hypersensitive
Re: as used command & command-s
« Reply #1 on: August 12, 2014, 03:01:00 AM »
Use the vl function instead vl-cmdf .
« Reply #2 on: August 12, 2014, 08:40:01 AM »
Or just move away from command calls:
(defun _thaw (name / e o)
  (if (setq e (tblobjname "layer" name))
    (if (minusp (vlax-get (setq o (vlax-ename->vla-object e)) 'freeze))
      (vlax-put o 'freeze 0)
;; (_thaw "0")
ribarm
  • Marko Ribar, architect
« Reply #3 on: August 12, 2014, 09:43:08 AM »
Untested (don't have A2015)... Before you execute routines type : command-switch, and after that type : command-restore...
  1. (defun c:command-switch nil
  2.   (if command-s
  3.     (setq com command command command-s)
  4.   )
  5.   (princ)
  6. )
  7.
  8. (defun c:command-restore nil
  9.   (if (and command-s com)
  10.     (setq command com com nil)
  11.   )
  12.   (princ)
  13. )
  14.
HTH, if my assumptions are correct...
M.R.
« Last Edit: August 12, 2014, 09:52:13 AM by ribarm »
M.R. on Youtube
TopoWAR
« Reply #4 on: August 12, 2014, 11:25:13 AM »
had already tried this function, but still fails in 2015
;; (_thaw "0")
in 15 thousand lines of code that I have, it would be more difficult to suppress the call command, I've used a lot
  2.   (if command-s
  4.   )
  5.   (princ)
  6. )
  7.
  11.   )
  12.   (princ)
  13. )
  14.
M.R.
Correct me if it is true, the function is being protected command, trying to replace it with another function daria error running the code, is this true ????
« Last Edit: August 12, 2014, 11:31:13 AM by TopoWAR »
Thanks for help
« Reply #5 on: August 12, 2014, 12:10:41 PM »
I understand, but if you're already going through your code and replacing command with command-s .. why not replace it with a commandless function ?
The solution with the least amount of effort would be:
(if command-s
    (setq command command-s)
If it's prompting about the assignment to protected symbol just turn it off in the vlide.
Tools>>Environment Options>>General Options>> SETQ to protected symbols>> Transparent
« Last Edit: August 12, 2014, 12:14:35 PM by ronjonp »
TopoWAR
« Reply #6 on: August 12, 2014, 01:17:17 PM »
ronjonp ,
is that I have not yet replaced by command-s command, I have to do and wanted to see if there is an easier solution, I very much like your proposal, but to try to replace the function code sticks because I pulled a screen says that the function is being protected command, I do? thanks friend
ahh I see, but my question is: to do this on all pc's where the code is run vlx if so would be complicated!
« Last Edit: August 12, 2014, 01:20:32 PM by TopoWAR »
Thanks for help
« Reply #7 on: August 12, 2014, 02:34:31 PM »
The file that setting is stored in is located in VLIDE.DSK here:
(vl-registry-read (strcat "HKEY_CURRENT_USER\\" (vlax-product-key)) "RoamableRootFolder")Set    (*protect-assign* . 0)
I'd personally take the time to go through the code and fix it though.
TopoWAR
« Reply #8 on: August 12, 2014, 02:52:24 PM »
ronjonp , my friend thank you very much :-)
Thanks for help
« Reply #9 on: August 12, 2014, 03:01:06 PM »
Glad to help  :)
dgorsman
« Reply #10 on: August 12, 2014, 05:11:43 PM »
Also a good argument for creating re-useable functions.  Instead of the same thing written out a few thousand times, a function call written once and called where needed.  When these things prop up, its only a matter of opening the one box, changing the contents, and everything outside the box is none the wiser.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
cmwade77
« Reply #11 on: August 12, 2014, 06:59:26 PM »
I'm not sure that I understand what the problem is, I have a fair number of routines that use (command and not (command-s and they all work fine in 2015.
« Reply #12 on: August 12, 2014, 09:57:21 PM »
Agreed ;)
velasquez
« Reply #13 on: November 05, 2014, 11:27:57 AM »
I do not understand the problem with command and command-s
I copied the lines below the help of AutoCAD 2015.
"(command-s "._circle" (getpoint "\nSpecify center point: ") "_d" 2.75)"
Turns out the lines of code work fine in AutoCAD 2015 and 2012.
1
(command-s "._circle" (getpoint "\nSpecify center point: ") "_d" 2.75)2
(command "._circle" (getpoint "\nSpecify center point: ") "_d" 2.75)
Can someone explain me better how to reproduce the error that is as reported.
I better understand all the comments about it.
ChrisCarlson
« Reply #14 on: November 05, 2014, 11:41:39 AM »
vl-cmdf is probably failing due to vl-load-com not being present. The . and _ also affect the running of a command. I have no idea what the difference between "circle " "_circle" and "._circle"
