Author Topic: Small but useful tip (I think) ...  (Read 3120 times)
« on: April 13, 2005, 07:40:56 PM »
In VB(A) one frequently simplifies one's code by using the "With" statement to eliminate redundant object references and/or make code more maintainable.
Instead of --
myObject.Method1 parameters
myObject.Method2 parameters
You might do this --
With myObject
    .Method1 parameters
    .Method2 parameters
End With
Thank you Michael, been doing that for years, move on son.
Hang on a sec.
What you might not realize is that you can use the "With" statement with any expression that returns an object or type.
Eh?
Ok, a quick, but real example. Say you're adding items to a listview object and each entry has sub items. Here's a typical approach --
Dim Item As ListItem
Set Item = listview1.ListItems.Add(, , "Item")
Item.SubItems(1) = "Detail 1"
Item.SubItems(2) = "Detail 2"
Which can be simplified to (and frequently is) --
With Item
End With
But what about --
With listview1.ListItems.Add(, , "Item")
End With
:cheesy:
\|// Set goal. Experiment tirelessly until
|Oo| practice has become expertise.  Loop.
|- | LinkedIn | Dropbox
« Reply #1 on: April 13, 2005, 09:10:49 PM »
This is the kind of tip that will allow good programmers to become great....
TR
« Reply #2 on: April 13, 2005, 09:50:50 PM »
Good tip. I use "with" whenever I can as I'm lazy and don't like to type. Also it produces nicer looking code.
« Reply #3 on: April 14, 2005, 10:34:35 AM »
Thanks guys, wasn't sure if it would be useful for or not but that apparently couldn't stop me from posting it. This of course has never happened to me before.
Jürg Menzi
  • Oberegg, Switzerland
« Reply #4 on: May 07, 2005, 11:52:21 AM »
And going further:
With MyGrid
  Set .DataSource = MyRecSet
  With .Columns(1)
    .Caption = "Cap1"
    .Width = 100
    .AllowSizing = False
    .Locked = True
  End With
  With .Columns(2)
    .Caption = "Cap2"
    .Width = 200
    .Locked = True
  End With
End With
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k14... A2k18 - Start R2.18
« Reply #5 on: May 07, 2005, 11:58:30 AM »
Good stuff Jürg, thanks.
Jürg Menzi
« Reply #6 on: May 08, 2005, 10:33:16 AM »
Glad to contribute... :D
Cheers
« Reply #7 on: May 08, 2005, 10:36:44 AM »
You have a lot to contribute Jürg, hope we see you here frequently.
:cheesy:
Jürg Menzi
« Reply #8 on: May 10, 2005, 03:38:48 PM »
Probably yes, but my greatest problem is to find enough time to scan/read all the threads in this forum. Maybe 'cause I'm not (yet) familiar with web based groups like TheSwamp. :(
Cheers
M-dub
« Reply #9 on: May 10, 2005, 03:43:17 PM »
One tip for you...
Create a Bookmark / Favourite and give it this address:
http://www.theswamp.org/phpBB2/search.php?search_id=newposts&sid=47b0892991d610d7b8377df9ea3906a0
(View posts since last visit)
Jürg Menzi
« Reply #10 on: May 11, 2005, 04:13:56 PM »
Quote from: M-dub
One tip for you...
Thx, that was it...
Cheers
