Author Topic: To get the string  (Read 2460 times)
2e4lite
To get the string
« on: August 07, 2014, 11:00:28 PM »
A known list:
'(("1" nil "France")("2" nil "Germany")("3" nil "Holland")("D" nil "Berne"))Is there a very easy and quick way to get the string to following?
"France(1)/Germany(2)/Holland(3)/Berne(D)/"Or
"France(1)/Germany(2)/Holland(3)/Berne(D)"
« Last Edit: August 07, 2014, 11:14:27 PM by 2e4lite »
Re: Is there a easy and quick way to get the string?
« Reply #1 on: August 07, 2014, 11:01:44 PM »
What code have you tried ?
2e4lite
Re: To get the string
« Reply #2 on: August 07, 2014, 11:04:29 PM »
Hey
    This is my way:(vl-string-trim "()" (vl-princ-to-string (mapcar '(lambda (x) (strcat (last x) "(" (car x) ")/")) lst)))
    Is there a better way ?
« Last Edit: August 07, 2014, 11:11:22 PM by 2e4lite »
« Reply #3 on: August 07, 2014, 11:11:31 PM »
This may be cleaner
  1. (apply 'strcat (mapcar '(lambda (x) (strcat (last x) "(" (car x) ")/")) lst))
dgpuertas
« Reply #4 on: August 08, 2014, 03:53:18 AM »
or maybe
(strcat (caddar lst) "(" (caar lst) ")"
   (apply (function strcat) (mapcar (function (lambda (l) (strcat "/" (caddr l) "(" (car l) ")"))) (cdr lst))))
->  "France(1)/Germany(2)/Holland(3)/Berne(D)"
« Reply #5 on: August 08, 2014, 08:27:35 AM »
And another to not have the trailing "/"
(vl-string-right-trim
  (apply 'strcat
       '(("1" nil "France") ("2" nil "Germany") ("3" nil "Holland") ("D" nil "Berne"))
« Reply #6 on: August 09, 2014, 06:13:45 AM »
Another:
  1. (defun f ( l )
  2.     (if (cdr l)
  3.         (strcat (caddar l) "(" (caar l) ")/" (f (cdr l)))
  4.         (strcat (caddar l) "(" (caar l) ")")
  5.     )
  6. )
  1. _$ (f '(("1" nil "France")("2" nil "Germany")("3" nil "Holland")("D" nil "Berne")))
  2. "France(1)/Germany(2)/Holland(3)/Berne(D)"
