I fixed the local variables. Can you post an example of 1 of your blocks? -David
You routine make changes to attribute string but it moves the attributes to '(0.0 0.0 0.0)
![sad :-(](http://www.theswamp.org/Smileys/black/sad.gif)
Thank you .
[/quote]
Try to use this:
Your codes make the attribute to top center and I am looking for left alignment .
Thank you .
I have error message after I modified your codes to make it left alignment ![embarrassed :embarrassed:](http://www.theswamp.org/Smileys/black/embarrassed.gif)
; error: Automation Error. Not applicable
Can you please help ?
Hint:
The InsertionPoint property controls the text position when the Alignment property is set to Left, the TextAlignmentPoint controls the text position for all other values of the Alignment property.
I got that lee , but I see the changes to left alignment does not affect the same thing as the attribute editor .
For example , if you change attribute from top center to left with the command eattedit , the attribute goes back to its original position and this is correct and perfect , but with
codes the attributes moves to left but its position keeps the attribute in its current position and this is my CONFUSION.
![shocked :-o](http://www.theswamp.org/Smileys/black/shocked.gif)
Thank you .
