Author Topic: hijacked dimensions  (Read 2567 times)
Bethrine
hijacked dimensions
« on: August 04, 2014, 04:27:18 PM »
What?? Why???  :x
It was fine and now it's not.   :cry:
Re: hijacked dimensions
« Reply #1 on: August 04, 2014, 04:29:57 PM »
fraction format settings are?
Bethrine
« Reply #2 on: August 04, 2014, 04:36:48 PM »
Where do I find those?
Another example:
Should be the top one I just added.
« Reply #3 on: August 04, 2014, 04:40:02 PM »
see
Bethrine
« Reply #4 on: August 04, 2014, 04:45:59 PM »
Okay, Why would those affect it?
I believe they are giving me the paper space dimension instead of the model space one. I checked and re-associated it and still the same measurement. But why??
« Reply #5 on: August 04, 2014, 04:55:06 PM »
see that box that says APPLY to LAYOUT Dimensions ONLY.....
you must scale paperspace to get modelspace distances
Bethrine
« Reply #6 on: August 04, 2014, 05:04:30 PM »
Is that not what this is for? Everything should be 1:1 save for the view-port scale. When I originally place them, they are correct.
I don't use annotative scaling either, I am dimensioning 3D objects through view-ports in paper space.
« Last Edit: August 04, 2014, 06:58:47 PM by Bethrine »
Jeff H
« Reply #7 on: August 04, 2014, 07:08:20 PM »
Is DIMASSOC set to 2?
Seem to remember under certain circumstances if set to 1 and dimension in paperspace it will give model space distance but will revert back to distance on sheet.
Try setting it to 2
Bethrine
« Reply #8 on: August 04, 2014, 07:18:39 PM »
Yep, Thank you. I am almost out of here today, I will check it out tomorrow. :D
Bethrine
« Reply #9 on: August 05, 2014, 12:00:00 PM »
Thank you Jeff H. I believe that's what is happening. Does anyone know a quick fix or do I need to re-associate every dimension?
I miss-read that.  :uglystupid2: It is set to 2.
« Last Edit: August 05, 2014, 12:53:50 PM by Bethrine »
« Reply #10 on: August 05, 2014, 12:06:24 PM »
no....that changes size(s) of dimension parameters - arrows, texts, extension lines,etc
Bethrine
« Reply #11 on: August 05, 2014, 12:45:18 PM »
Yeah, I spent my morning learning how to use annotative scaling on a 3D object. I have the basics of it now. I'm working on the kinks, so to speak. See attached.
Both dimension and text height are set to 0.125. They don't both print the same height though. ??? Any help appreciated!
Also, I think isometric views don't annotate well that way and I will have to stick to paper space there.
« Last Edit: August 05, 2014, 12:59:21 PM by Bethrine »
