Author Topic: Service Pack 2 for Map 3D 2015 released  (Read 3530 times)
huiz
  • Certified Prof C3D
« on: August 01, 2014, 03:41:38 AM »
SP2 is now available for Map3D 2015 and Infrastructure Administrator 2015 (Industry Models).
These are 2 different service packs. If you use Industry Model functionalities you are required to install also the SP for the Infrastructure Administrator 2015.
The SP for Infrastructure Administrator 2015 does not show up in the Autodesk Application Manager so please following the link below to download.
Download Service Pack 2 for Autodesk AutoCAD MAP 3D 2015 and Infrastructure Administrator 2015
Please note if you use IM with Oracle and SQL Server you need to open the Autodesk Industry Model Setup and update Mapsys user before you start using IM again.
