Author Topic: Steel Shapes - Dynamic/Parametric  (Read 20551 times)
Bob Garner
Re: Steel Shapes - Dynamic/Parametric
« Reply #15 on: August 07, 2014, 10:59:33 AM »
File sent.  If you don't receive, let me know.
Bob
« Reply #16 on: August 27, 2014, 08:37:04 AM »
Back at it.
Bob, no file received.
Latest Update: (work in progress)
Added Angles
« Last Edit: August 27, 2014, 11:54:06 PM by CAB »
RC
« Reply #17 on: September 02, 2014, 06:26:48 PM »
Thanks CAB,
One day soon I'm going to seal this code and make it 3D (unit blocks of solids 1" thk.  inserted with a "Z" or "X" scale for length).
« Reply #18 on: September 02, 2014, 11:57:08 PM »
Oh, good idea.
I'll add a 3D option in the Dialog.
Where have you been hiding? :)
RC
« Reply #19 on: September 11, 2014, 04:55:47 PM »
up to my keester in alligators ...
working for a much smaller company now and that means no time for anything but work.
« Reply #20 on: September 11, 2014, 06:07:00 PM »
Well at least you have a job.  :)
I'm busy again but almost 3 years with little or no pay.
My wife carried me, bless her heart.  ;)
Bob Garner
« Reply #21 on: September 11, 2014, 07:48:05 PM »
I've been asleep at the switch.  CAB do you still want those aluminum shape files?
Bob
« Reply #22 on: September 11, 2014, 09:51:18 PM »
Sure, I've been busy learning Chief Architect >:D , but still want to pursue the LISP.
I think I have the steel shapes listed in the routine working.
The aluminum shapes should be added too.
Bob Garner
« Reply #23 on: September 12, 2014, 09:25:47 AM »
CAB,
Here's another shot at sending the Aluminum Association shapes file.  I'll try the zipped one first.  Let me know.
And thanks for putting these DB's together!
Bob
RC
« Reply #24 on: September 12, 2014, 09:48:14 AM »
I've stayed employed, but the big place became embroiled in rabid in-fighting among the teams of the different acquisitions.  I got tired of the whining and b1tching after a few months, disbanded my team and walked away.   Found a small company that needed help, went back on my tools, I am a designer again and loving every minute, I don't supervise, I don't manage, I don't schedule, I don't even check, I just sit in my corner cube and build refineries.
hermanm
« Reply #25 on: October 25, 2014, 08:46:29 AM »
Mine is database driven... I can't share it in it's current state.
I have plans to re-write parts of the Application and release it into the wild. I don't have a timeframe at the moment.
The App draws elevations, plans and sections in 2D ... and adds xdata to assist in data extraction.
Ditto.:)
« Reply #26 on: October 25, 2014, 05:05:26 PM »
Wow, very nice DCl, lots of options too.
What is the distort dimensions about?
« Reply #27 on: October 25, 2014, 06:55:58 PM »
Wild assed Guess :
Provide the option to exaggerate the thickness on the flange or web. This will draw the lines further apart and stop bleeding when printing, thus retain visual 'representational' integrity.
... sort of like we did 25 or 30 years ago on the board. ( when we didn't have an accurate 'distance' command :-) )
hermanm
« Reply #28 on: October 25, 2014, 10:22:41 PM »
Correct.
danallen
« Reply #29 on: January 20, 2015, 06:40:13 PM »
One problem I don't know how to fix is making the insertion point the "top of steel"...the middle of the top flange. Is it possible to change the insert point once it has already been defined?
http://www.lee-mac.com/changeblockinsertion.html
