Author Topic: Steel Shapes - Dynamic/Parametric  (Read 20545 times)
T-Square
« on: July 30, 2014, 05:20:05 PM »
Never mind.....
« Last Edit: February 16, 2015, 05:45:15 PM by T-Square »
Re: Wide Flange - Dynamic/Parametric
« Reply #1 on: July 31, 2014, 04:44:14 PM »
No luck opening the DWG for me here in ACAD2006 even after converting back to 2004. It returns plain line work.
I'll see if I can create from scratch.
Re: Steel Shapes - Dynamic/Parametric
« Reply #2 on: July 31, 2014, 08:40:38 PM »
Sorry no can do Civil or other off shoots especially "parametric" objects.
If it were me I would do it with Lisp and anonymous blocks.
I think Kerry had a routine to do some steel shapes. Maybe I'm miss remembering.
« Reply #3 on: July 31, 2014, 08:48:23 PM »
Mine is database driven Alan. I can't share it in it's current state.
I have plans to re-write parts of the Application and release it into the wild. I don't have a timeframe at the moment.
The App draws elevations, plans and sections in 2D or 2D and adds xdata to assist in data extraction.
« Last Edit: July 31, 2014, 08:52:51 PM by Kerry »
« Reply #4 on: July 31, 2014, 09:25:19 PM »
Is the "AISC Shapes Database v14.1" database open source ??
I work in metric land.
AISC for me is Australian Institute of Steel Construction. ... and they don't produce a database. We rely on information from steel suppliers/producers.
« Reply #5 on: August 01, 2014, 08:55:38 AM »
Not sure about propriotary numbers but this site has a very slight deviation on some numbers http://www.engineersedge.com/standard_material/Steel_ibeam_properties.htm
« Reply #6 on: August 03, 2014, 03:32:34 PM »
Tim,
You may want to give this a try. Just some code I threw together to use your text file as a database.
DCL file attached
;;;                       wShapes.lsp                                  ;
;;;                   Revision 1.3 08/03/14                            ;
;;;                   Charles Alan Butler                              ;
;;;                      TheSwamp.org                                  ;
;;;                     @ Copyright 2014                               ;
;;;  ASCI Steel W shapes, end view, using a data text file ""
;;;  The routine offers the user a DCl pick list to choose a W Steel Shape
;;;  and adds that shape to the drawing as a block with two hidden attributes.
;;;  You may modify the attribute creation by editing the setq attdata line
;;;  below. The Layer of the Insert is also found below with variable InsLay.
;;;  Currently set to "0" No layer check is made at this time. If the block
;;;  already exist it is simply inserted. The user picks insert point and
;;;  then rotation.
;;;  THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED      ;
;;;  WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR   ;
;;;  PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.             ;
;;;  Copyright 2014  by Charles Alan Butler. All Rights Reserved.      ;
;;;  You are hereby granted permission to use, copy and modify this    ;
;;;  software without charge, provided you do so exclusively for       ;
;;;  your own use or for use by others in your organization in the     ;
;;;  performance of their normal duties, and provided further that     ;
;;;  the above copyright notice appears in all copies and both that    ;
;;;  copyright notice and the limited warranty and restricted rights   ;
;;;  notice below appear in all supporting documentation.              ;
;;;  Copying, modification and distribution of this software or any    ;
;;;  part thereof in any form except as expressly provided herein is   ;
;;;  prohibited without the prior written consent of Charles Alan      ;
;;;  Butler, 1403 Duelda Drive, Brandon Florida, 33511                 ;
(defun c:wshapes (/ path filename handle stream result InsBlk insLay wShapeDBfn attdata *error*)
  (setq InsLay "0") ; layer to use for Block Insert
  ;; add attributes to BlockDef
  ;;  AttData list of list with 3 strings  '((TAG Prompt DefVal)("DATA1" "Prompt1" "DefValue1"))
  ;;  This example add 2 hidden attributes to each new block
  (setq attdata '(("DATA1" "Prompt1" "DefValue1")("DATA2" "Prompt2" "DefValue2")))
  (setq wShapeDBfn "AISC_SHAPE_W.txt")
  ;; error function & Routine Exit
  (defun *error* (msg)
    (if (not (member msg '("console break" "Function cancelled" "quit / exit abort" "")))
    ) ; endif
    (and usrosmode (setvar "osmode" usrosmode))
    (and usrormode (setvar "orthomode" usrormode))
    (if (and MoveStarted Ins)
      (command "._erase" Ins "")
  ;;  parser by CAB single character delim, match ","
  (defun sparser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
  ;;  convert the text to a number - CAB
  (defun txt2num (txt / num)
    (or (setq num (distof txt 5))
        (setq num (distof txt 2))
        (setq num (distof txt 1))
        (setq num (distof txt 4))
        (setq num (distof txt 3))
    num
  (defun getdata (lst / nlst L sl sl2)
    (foreach ln lst
      (setq l   (sparser ln "\t")
            sl  (car l)
            l   (cdr l)
            sl2 nil
      (if (/= "" (vl-string-trim " \t\n" sl)) ; skip blank lines
          (foreach itm l (setq sl2 (cons (txt2num itm) sl2)))
          (setq l (cons sl (reverse sl2)))
          (setq nlst (cons l nlst))
    nlst
  (defun makedatabase (filename / path handle result stream)
    (if (null wdatabase*)
      (if (setq path (findfile filename))
        (if (setq handle (open path "r"))
            (while (setq stream (read-line handle))
              (setq result (cons stream result))
            (setq wdatabase* (getdata result))
  ;;  by CAB 10/05/2007
  ;;  Expects pts to be a list of 2D or 3D point lists
  ;;  Returns new pline object
  (defun makepline (spc pts / norm elv pline)
    (setq norm (trans '(0 0 1) 1 0 t)
          elv  (caddr (trans (car pts) 1 norm))
    ;;  flatten the point list to 2d
    (if (= (length (car pts)) 2) ; 2d point list
      (setq pts (apply 'append pts))
      (setq pts (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) pts)))
    (setq
      pts (vlax-make-variant
            (vlax-safearray-fill
              (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pts))))
              pts
    (setq pline (vla-addlightweightpolyline spc pts))
    (vla-put-elevation pline elv)
    (vla-put-normal pline (vlax-3d-point norm))
    (vla-put-closed pline :vlax-true)
    (vla-put-layer pline "0")
    ;;(vla-put-Color PolObj AcYellow)
    ;;(vla-put-Linetype PolObj "HIDDEN")
    pline
  ;;    sname    dep bf   tw   tf
  ;;  ("W12X16" 12.0 4.0 0.25 0.25 0.8125 0.5625)
  (defun makewshape (space data attdata / att attdata atts bf blkdef bn d doc l1 l2 p1 p10
                     p11 p12 p13 p2 p3 p4 p5 p6 p7 p8 p9 plobj r tf tw x y)
    (mapcar '(lambda (x y) (set x y)) '(bn d bf tf tw x y) data)
    (if (tblsearch "block" bn) ; block exist
      (vlax-invoke space 'insertblock (trans '(0. 0. 0.) 1 0) bn 1. 1. 1. 0.)
        ;; make the shape with pline, chamfer ILO arc at web
        ;; p2 is lower left point
        ;; radius at web is undifined by ASCI & left to the Manufactures
        ;; This shape uses 1/2 the web thickness (tw) for the chamfer
        ;; Chamfer points occur at p5 p6 p11 p12 so in place of p5 use
        ;;  (vadd p5 (list 0. r)) (vadd p5 (list r 0.))
        (defun vadd (v1 v2) (mapcar '+ v1 v2))
        (setq p1  '(0. 0.)
              l1  (/ bf 2.) ; 1/2 base
              l2  (- l1 (/ tw 2.))
              r   (/ tw 2.) ; chamfer value
              p2  (vadd p1 (list (- l1) 0.)) ; 0 = no change
              p3  (vadd p2 (list bf 0.))
              p4  (vadd p3 (list 0. tf))
              p5  (vadd p4 (list (- l2) 0.))
              p6  (vadd p5 (list 0. (- d (* tf 2))))
              p7  (vadd p6 (list l2 0.))
              p8  (vadd p7 (list 0. tf))
              p9  (vadd p8 (list (- bf) 0.))
              p10 (vadd p9 (list 0. (- tf)))
              p11 (vadd p10 (list l2 0.))
              p12 (vadd p11 (list 0. (- (- d (* tf 2)))))
              p13 (vadd p12 (list (- l2) 0.))
        ;;  create the block def
        (setq doc (vla-get-activedocument (vlax-get-acad-object)))
        (setq blkdef (vlax-invoke (vla-get-blocks doc) 'add '(0. 0. 0.) bn))
        (foreach itm attdata
          (setq atts ; list of enames for the attribute Def
                 (cons
                    ;;  AddAttribute     (Height, Mode,  Prompt,    InsertionPoint,   Tag,   Value)
                    ;;(setq att (vla-AddAttribute blk 0.5 acAttributeModeInvisible (cadr itm) p1 (car itm) (caddr itm)))
                    (setq att (vlax-invoke blkdef 'addattribute 0.5 1 (cadr itm) '(0. 0. 0.) (car itm) (caddr itm)))
                   atts))
          (vla-put-layer att "0")
        ) ; end foreach
        ;;  chamfer added to web, pline obj added to BlockDef
        (setq plobj (makepline blkdef (list p2 p3 p4
                                           (vadd p5 (list r 0.)) (vadd p5 (list 0. r))
                                           (vadd p6 (list 0. (- r)))  (vadd p6 (list r 0.))
                                           p7 p8 p9 p10
                                           (vadd p11 (list (- r) 0.))  (vadd p11 (list 0. (- r)))
                                           (vadd p12 (list 0. r)) (vadd p12 (list (- r) 0.))
                                           p13))) ; vla object
    ) ; endif
  ;;  DCL routine for user to select shape from database
  ;;  Returns the shape name i.e.  "W4X12"
  (defun getuserpick (database picked / dclfile dcl# fn shapepick)
    (setq fn "wShapes.dcl")
      ((not (setq dclfile (findfile fn))) (prompt (strcat "\nCannot find " fn ".")))
      ((< (setq dcl# (load_dialog dclfile)) 0) (prompt (strcat "\nCannot load " fn ".")))
      ((not (new_dialog "shapesdialog" dcl#)) (prompt (strcat "\nProblem with " fn ".")))
      ((setq shapepick (doit dcl# database picked)) ; No DCL problems: fire it up
       ;;  returns the shape name or nil
    ) ; end cond
  ;;                  Run the Dialog
  (defun doit (dcl_id data pick / action fulllst n pick)
    (setq fulllst (mapcar 'car data)) ; list of only shape names
    (start_list "shapelist")
    (mapcar 'add_list fulllst)
    (end_list)
    ;;  Update filename display for list box
    (action_tile "shapelist" "(setq pick (nth (atoi $value) fulllst))")
    (if (setq n (vl-position pick fulllst))
      (set_tile "shapelist" (itoa n))
      (set_tile "shapelist" "0")
    (action_tile "Insert" "(done_dialog 2)")
    (action_tile "HelpDialog" "(done_dialog 5)")
    (action_tile "Done" "(done_dialog 0)")
      (setq action (start_dialog))
      ((= action 1) (setq pick null)) ; exit
      ((= action 2)) ; exit
      ((= action 5) (setq pick null)) ;
      ((setq pick null)) ; unknown code
    (unload_dialog dcl_id)
    pick
  ) ; end defun
  ;;  This is my clumsy routine to move & rotate an Insert. It repeats with the same Block
  ;;  until user hits Enter or Escape
  (defun MoveBlock (obj spc lay / ins movestarted npt ormodetmp osmodetmp pt shape usrormode usrosmode bn)
    (setq pt '(0 0))
    (setq usrosmode (getvar "osmode")) ; reset when routine ends
    (setq usroRmode (getvar "orthomode")) ; reset when routine ends
    (setq osmodetmp (getvar "osmode")) ; temp setting
    (setq ormodetmp (getvar "orthomode")) ; temp setting
    (setq bn (vla-get-name obj))
    ;; (setvar "osmode" 0)
    (while
        (setq MoveStarted t)
        (setvar "orthomode" 0)
        (setq Ins (vlax-vla-object->ename obj))
        (vla-put-layer obj Lay) ; Layer of Insert
        (command "._move" Ins "" pt)
        ;;(setvar "osmode" osmodetmp)
        (command pause)
        (if (or (and (null npt) (setq npt (getvar "lastpoint")))
                (> (distance pt (setq npt (getvar "lastpoint"))) 0.001))
            ;;  allow user to rotate
            (setvar "orthomode" 1)
            (command "._rotate" Ins "" "_non" npt)
            (command pause)
            (setq MoveStarted nil)
            (command "._undo" "_end")
            (command "._undo" "_begin")
            ;;  Add a new Insert
            (setq obj (vlax-invoke spc 'insertblock (trans '(0. 0. 0.) 1 0) bn 1. 1. 1. 0.))
            t ; stay in loop
    ) ; while
    (*error* "")
  ;;                    Start of Routine
  (setq space
         (if (= 1 (getvar "CVPORT"))
           (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object)))
           (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
  (or UserShapePick (setq UserShapePick "")) ; string = to 1st item in list "W4X12"
  ; (setq wdatabase* nil) ; debug
    ((not (or wdatabase* (makedatabase wShapeDBfn))) ; load database from text file
     (princ "\nDatabase Failed to Load.")
    ((not (setq shape (getuserpick wdatabase* UserShapePick))) ; need user selection
     (princ "\nUser Quit or Problem with DCL.")
    ((setq data (assoc shape wdatabase*))
     ;;  got new shape
     (setq UserShapePick shape)
     ;;  make block if not in drawing
     (setq InsBlk (makewshape space data attdata)) ; add block to DWG & Insert @ 0,0
     (if insBlk ; move it into position
       (MoveBlock InsBlk space InsLay)
    ((princ "\nUser Quit."))
« Reply #7 on: August 04, 2014, 04:09:22 PM »
I just used a 1/4 tw chamfer ILO radius. As for the radius see this https://www.aisc.org/DynamicTaxonomyFAQs.aspx?id=1524
« Reply #8 on: August 04, 2014, 07:35:28 PM »
Thanks, changed my copy too.
« Reply #9 on: August 06, 2014, 07:44:00 AM »
Tim,
Did you get a chance to try out the Lisp?
Bob Garner
« Reply #10 on: August 06, 2014, 09:41:25 AM »
I suppose you all know that the HSS shape properties are based on reduced steel thickness to allow for production tolerances so their thickness values are something like 97% of theoretical.  If it says HSS 3x3x1/4", it isn't quite 1/4".  The AISC tables allow for this.
Are you basing your blocks on the actual dimensions or the detailing dimensions?  For drafting purposes, I would vote for detailing dimensions.
The k and k sub 1 values are important for detailing purposes and I make sure I get these accurate.
I still draw my steel sections by hand!  There's a certain Zen while I think about my detail layout and draw up a series of steel sections that may work.  By the time I draw up several sections, my mind has already figured out what will go where.
But I would die for your program.  Someone did one for structural bolts and I owe them large.  A late thanks to him and an early thanks to you.
Bob
« Reply #11 on: August 06, 2014, 11:33:03 AM »
Bob,
Thanks for the heads up. My use is occasional sections in a building structure so machine tolerances are not a factor for me.
I too was drawing them by hand but the thrill is gone and I took this opertunity to automate the process. I have no need for the attributes at this time but Tim did so I included some generic atts & an easy way  to customize them. I suppose the 3% reduction in actual size can be incorporated in easy enough. Especially if it is uniform on all measurements.
My use is as a semi-smart Draftsman for an Engineer. I'm knowledgeable when it comes to houses & wood etc but Steel members is an area I'm still learning. Don't do enough of it to retain so i look up data a lot when working with it. The engineer calls out the member in his pencil sketches & I have to look up the particulars. I suppose I will add rectangular tubing next. Or maybe aluminum I-beams. That won't happen until I return from vacation (14-21). maybe radio buttons for the shape & type or another pick list if the list grows.
Just rambling a bit.
« Reply #12 on: August 06, 2014, 11:38:07 AM »
A quick google and I see the data base for HSS Square & Rectangular Sections is available
http://www.lisaed.com/hsssq.html
PS I will add code to ignore semicolons in the text database file so I can add a header.
« Last Edit: August 06, 2014, 11:42:38 AM by CAB »
Bob Garner
« Reply #13 on: August 06, 2014, 11:08:20 PM »
Thank you for your efforts, Tim and Cab.
Cab, I've got a later edition of the Aluminum Association Manual with all the latest aluminum shapes.  If you get back from vacation and you are still even thinking of sitting down to the computer, then you blew your vacation  - no, I was going to say I'll send you whatever aluminum stuff you want.  Since it's for educational use, no breach of copyright.
What did you do on vacation?
Bob
« Reply #14 on: August 07, 2014, 10:27:15 AM »
Bob,
Haven't left yet. Out from 8/14 to 8/21 going to Roan Mountain, TN.
Yes send me the stuff when you can.
I may have time to play before i leave. Hot and heavy today & tomorrow though.
« Last Edit: August 07, 2014, 03:04:41 PM by CAB »
