Author Topic: set a default page setup for all drawing in folder  (Read 5000 times)
stevedallas
« on: July 29, 2014, 12:38:14 PM »
Frequently I get drawings in a job folder that multiple peaple have been in...fine.
When I go to plot the job as pdf's, some pages are 30", some are 11x17.
I would like to find something that can set each layout tab of each drawing in the folder to the same page setup so that all sheet sizes, settings, etc are all the same.
I saw a feature in trueview that can import a page setup into multiple drawings, but it does not set it as the default.
Basically, it would make publishing easier.
I though about sheetlists, but seem to have trouble getting them to get arranged like I want, even adding layouts to lists.
So, I figured setting each page setup the same and doing a publish would be better.
Perhaps a lisp that I can select the proper folder, then select a page setup, then it would go into each dwg and set it as default.
BlackBox
Re: set a default page setup for all drawing in folder
« Reply #1 on: July 29, 2014, 01:36:08 PM »
Firstly, PUBLISH automagically applies a named page setup to multiple drawings from the dialog; simply import your sheets, select all, and set the top sheet's page setup accordingly and they'll all use the same named page setup. This is not persistent; only for the publish process.
That said, if you're still determined to literally import the page setup into each drawing, and then set it active, give this old post a try.
Quote from: BlackBox
vla-SetActivePageSetup
Sets a named page setup active for a given layout by name
(vla-SetActivePageSetup layoutName pageSetupName)
Arguments
layoutName
A string specifying the name of a layout to apply the named page setup.
pageSetupName
A string specifying the page setup to apply to the layout.
Return Values
Nil if either the layoutName, or pageSetupName cannot be found. Otherwise, T if successful.
Example
  1. (foreach layoutname (layoutlist)
  2.   (vla-SetActivePageSetup layoutname “YourPageSetupName”)
  3. )
  4.
« Last Edit: July 29, 2014, 01:43:24 PM by BlackBox »
stevedallas
« Reply #2 on: July 29, 2014, 02:40:30 PM »
Can you post the autoloader bundle from previous posts?
I tried the augi link and others, would not let me get to it.
I am running Autocad 2012.
BlackBox
« Reply #3 on: July 29, 2014, 03:05:39 PM »
Here you go (see attached); this .bundle could use a great deal of updating, and will need to be recompiled to support 2015, but currently supports 2012-2014 as-is.
HTH
[Edit] - Attachment(s) removed; see this post for replacement.
« Last Edit: July 30, 2014, 05:19:02 PM by BlackBox »
stevedallas
« Reply #4 on: July 29, 2014, 03:08:10 PM »
Thank you.
BlackBox
« Reply #5 on: July 29, 2014, 03:08:58 PM »
Thank you.
You're welcome; I hope this helps.
Cheers
stevedallas
« Reply #6 on: July 29, 2014, 05:31:02 PM »
OK, CRAZY QUESTION.
How do I unstall?
BlackBox
« Reply #7 on: July 29, 2014, 05:32:32 PM »
OK, CRAZY QUESTION.
How do I unstall?
Simple - Remove the .bundle you placed in your ..\ApplicationPlugins\ folder.
stevedallas
« Reply #8 on: July 30, 2014, 08:25:43 AM »
oops, I meant to say "install" on my previous message, not "unstall".
But, I dropped it in the applications plugin folder.
Now, How do I use it?
It there a way of testing it, such as dropping
(foreach layout1 (layoutlist) (vla-SetActivePageSetup layoutname “pdf 24-36”))
on the command line?
BlackBox
« Reply #9 on: July 30, 2014, 08:29:17 AM »
No worries.
You can test it at the command line, as you've noted above, so long as the named page setup exists within that drawing... Or you can paste same in VLIDE and you should see that the custom LispFunction Method is a 'native' function (unlike your own Defun, presuming you're not using Pragma on your custom LISP).
stevedallas
« Reply #10 on: July 30, 2014, 03:30:57 PM »
Is there a way that I can tell if the plugin loaded successfully?
BlackBox
« Reply #11 on: July 30, 2014, 04:07:39 PM »
What happens when you try either of these?
[Edit] - What is reported to the command line when you invoke the APPAUTOLOADER Command?
stevedallas
« Reply #12 on: July 30, 2014, 04:15:14 PM »
Command: (foreach layoutname (layoutlist) (vla-SetActivePageSetup layoutname
“pdf 30-42”))
; error: LispException: too many arguments
; error: LispException: too many argumentsnil
stevedallas
« Reply #13 on: July 30, 2014, 04:17:59 PM »
Is "layoutname" a variable that (layoutlist)  dumps into?
My drawings usually have multiple layout tabs.
BlackBox
« Reply #14 on: July 30, 2014, 05:17:19 PM »
Not sure what's happened on your end  :?, but at the risk something got messed up in downloading/posting the .bundle here, I've just debugged this plug-in in 2012, 2014, and 2015 using Client Hyper-V & Visual Studio 2013 (see respective images attached).
As a result, I've subsequently revised the app .bundle to now support 2012-2015, so simply delete the earlier copy, and see the bottom of this post for a replacement .bundle.zip file.
Cheers
« Last Edit: July 30, 2014, 05:20:26 PM by BlackBox »
