Frequently I get drawings in a job folder that multiple peaple have been in...fine.
When I go to plot the job as pdf's, some pages are 30", some are 11x17.
I would like to find something that can set each layout tab of each drawing in the folder to the same page setup so that all sheet sizes, settings, etc are all the same.
I saw a feature in trueview that can import a page setup into multiple drawings, but it does not set it as the default.
Basically, it would make publishing easier.
I though about sheetlists, but seem to have trouble getting them to get arranged like I want, even adding layouts to lists.
So, I figured setting each page setup the same and doing a publish would be better.
Perhaps a lisp that I can select the proper folder, then select a page setup, then it would go into each dwg and set it as default.
