Author Topic: Dynamic Attribute  (Read 3965 times)
Dave20165
Dynamic Attribute
« on: July 28, 2014, 02:37:02 PM »
Hello,
Does anyone know if there is a way I can have a block or text field update additional fields within itself based on the users inputted value?
That's confusing, here....
Text reads like this:
FF=363.00
GAR=361.00
BF=353.17
If I change one of the values, lets say the garage floor elevation, I want the First Floor(GAR +2') to update and the Basement Floor(GAR -7.83') to update.
Has anyone seen anything like this used before?  I've tried researching "fields" but did not find what I was looking for.
Thanks!
Re: Dynamic Attribute
« Reply #1 on: July 31, 2014, 09:15:52 AM »
Yes it can be done with field(s)
First  Mtext for FF=, then another piece of text for first value (assuming you are entering manually)
Then mtext for GAR= then a field - first use object, select the second text string from above, and CONTENTS
from bottom of filed dialogue copy the field expression-then change field type to formula
paste in the value you just copied- do the math operation....repeat for next value
