Author Topic: Function returns an object  (Read 3412 times)
assafius
« on: July 27, 2014, 09:56:04 AM »
Wrote a simple code in autocad VBA that for some reason failed to run:
Function myFunc(p As ACAD_POINT) As Object
        Dim r As Object
        myFunc = r
End Function
Sub MySub()
       Dim p1 As ACAD_POINT
       Dim obj As object
       set obj = MyFunc(p1)
End Sub
When I execute MySub I get an error message: "object variable or with block variable not set"
does anyone know why ?
Thanks !
owenwengerd
Re: Function returns an object
« Reply #1 on: July 27, 2014, 05:06:04 PM »
You've declared r as Object, but you haven't given it a value (e.g. Set R = <whatever>).
