Author Topic: Problem with move to dim style in a block  (Read 4002 times)
Re: Problem with move to dim style in a block
« Reply #15 on: July 28, 2014, 09:24:35 AM »
Exactly!!  :(
LE3
« Reply #16 on: July 28, 2014, 09:45:58 AM »
no idea, but maybe there are these two methods or something related/similar in vlisp?
Code - C#: [Select]
  1. dimension.RecomputeDimensionBlock(true);
  2. dimension.RecordGraphicsModified(true);
Coder
« Reply #17 on: July 29, 2014, 11:10:39 AM »
Code - C#: [Select]
Thank you LE for your reply .
I searched for an equivalent function in lisp but couldn't find anything , do you have any suggestion ?
Thank you .
