Author Topic: Creating a very simple Jig  (Read 1285 times)
dawido000
« on: July 26, 2014, 04:21:29 AM »
I would like to create a Jig similar to autocad polyline function. Unfortunately I don't know how to enter value from keyboard, which specifies polyline length. There is short desktop capture in attachment.
GumbyCAD
Re: Creating a very simple Jig
« Reply #1 on: July 28, 2014, 01:59:44 AM »
I tryed to go down that path too, then found this.
Worked for me.
    Private Function DrawPolyGraphics() As ObjectId
        Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("cmdecho", 0)
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Dim RetOID As ObjectId = ObjectId.Null
        Dim msg As String = vbLf & "Pick first point: "
        Dim ppo As New PromptPointOptions(msg)
        ppo.AllowNone = True
        Dim usept As Boolean = False
        Dim ppr As PromptPointResult = ed.GetPoint(ppo)
        Dim pnt As Point3d = ppr.Value
        ppo.UseBasePoint = True
        ppo.UseDashedLine = True
        ppo.Keywords.Add("Undo")
        Dim undokKeyword As Keyword = ppo.Keywords(0)
        Using DokLock As DocumentLock = doc.LockDocument
            Using Trans As Transaction = doc.TransactionManager.StartTransaction()
                doc.TransactionManager.EnableGraphicsFlush(True)
                Dim btr As BlockTableRecord = DirectCast(Trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Dim pl As New Polyline()
                Dim plan As Plane = pl.GetPlane()
                pl.AddVertexAt(0, pnt.TransformBy(ed.CurrentUserCoordinateSystem).Convert2d(plan), 0, 0, 0)
                If MyDialogSettings.LayerName <> String.Empty Then
                    Dim LayerTab As LayerTable = DirectCast(Trans.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
                    If LayerTab.Has(MyDialogSettings.LayerName) Then
                        pl.Layer = MyDialogSettings.LayerName
                    Else
                        ed.WriteMessage("Current Drawing is missing " & MyDialogSettings.LayerName & ", Contact CAD Support" & vbCrLf)
                    End If
                End If
                btr.AppendEntity(pl)
                RetOID = pl.ObjectId
                Trans.AddNewlyCreatedDBObject(pl, True)
                Trans.TransactionManager.QueueForGraphicsFlush()
                Dim strHandle As String = pl.Handle.ToString()
                Do
                    ppo.BasePoint = pnt
                    undokKeyword.Enabled = pl.NumberOfVertices > 1
                    msg = vbLf & "Pick next point: "
                    ppo.Message = msg
                    ppr = ed.GetPoint(ppo)
                    If ppr.Status = PromptStatus.Cancel Then
                        Return ObjectId.Null
                    End If
                    If ppr.Status = PromptStatus.Keyword Then
                        pl.RemoveVertexAt(pl.NumberOfVertices - 1)
                        If pl.NumberOfVertices > 1 AndAlso pl.GetBulgeAt(pl.NumberOfVertices - 2) <> 0 Then
                            pl.SetBulgeAt(pl.NumberOfVertices - 1, 0)
                        End If
                        pnt = pl.GetPoint3dAt(pl.NumberOfVertices - 1)
                        pl.Draw()
                    End If
                    If ppr.Status = PromptStatus.OK Then
                        pnt = ppr.Value
                        pl.AddVertexAt(pl.NumberOfVertices, pnt.TransformBy(ed.CurrentUserCoordinateSystem).Convert2d(plan), 0, 0, 0)
                    End If
                    usept = True
                    ppo.BasePoint = pnt
                Loop While ppr.Status = PromptStatus.OK
                doc.TransactionManager.FlushGraphics()
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CMDECHO", 1)
                ' pl.MinimizeMemory();// UpdateScreen do it instead
                ed.UpdateScreen()
                Trans.Commit()
            End Using
        End Using
        Return RetOID
    End Function
