Author Topic: mText to Single line mText?  (Read 11152 times)
« on: July 25, 2014, 09:52:00 AM »
A quick search and no luck. I have some mText which I want single lines of text BUT I want the fractions to remain as is.
So Explode doesn't work for me in 2006 as it breaks the lines up where fractions occur.
Has any one seen that routine? Mtext to Mtext as individual lines?
One hurdle I have is that the line spacing is 0.80 so matching the line spacing is a concern too. Although not a big one.
A bonus is a routine that would detect line wrap for those mtext with width > 0 and break at the line wrap.
I have no time today to LISP so I thought I'd ask before diving into it this weekend.  :)
Or just break down & do it by hand.
If no one has the routine don't spend any time over it, I'll get buy.
I'll be out of the office for 6 hours or so.
trogg
Re: mText to Single line mText?
« Reply #1 on: July 25, 2014, 10:34:39 AM »
Here's one from Black Box:
http://forums.augi.com/showthread.php?71721-Multi-line-Mtext-to-Single-line-Mtext
Modified post to remove code since it goes help the CAB's request - sorry Charles
« Last Edit: July 25, 2014, 11:36:00 PM by trogg »
andy_lee
« Reply #2 on: July 25, 2014, 11:26:24 AM »
(defun maketext(ene1 / dat pt str natype txth)
  (setq dat (entget ene1))
  (setq pt (cdr (assoc 10 dat)))
  (setq str (cdr (assoc 1 dat)))
  (setq natype (cdr(assoc 7 dat)))
  (setq txth (cdr(assoc 40 dat)))
  (entmake (list '(0 . "TEXT") (cons 1 str) (cons 10 pt) (cons 8 "hatch") (cons 62 37) (cons 40 txth) (cons 7 natype)))
  (entdel ene1)
  );;;;separation...
andy.
Best regards.
« Reply #3 on: July 25, 2014, 01:06:06 PM »
That one uses EXPLODE which breaks fractions into separate text & caused the routine to crash.
« Reply #4 on: July 25, 2014, 01:12:09 PM »
emk2012, that one returns a plain text object which is not what I was looking for, but thanks for the reply.
Here is the mtext I am working with.
  (entmake '((0 . "MTEXT") (100 . "AcDbEntity") (67 . 0) (8 . "zDtl GenNotes") (62 . 6) (100 . "AcDbMText") (10 0.0 0.0 0.0) (40 . 3.0) (41 . 0.0) (71 . 1) (72 . 1)
       (3 . "\\A1; NUMBER AND TYPE \\POF FASTENER {\\H0.7x;\\Sa,b,c/;} \\P\\P3-8d (2{\\H0.7x;\\S1#2;} x0.113\")\\P\\P2-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P2 staples, 1{\\H0.7x;\\S3#4;}\" \\P\\P2-16d (3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P16d (3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P2-16d (3{\\H0.7") (3 . "x;\\S1#2;}\" x0.135\") \\P\\P3-8d or 2-16d \\P(3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P10d (3\" x0.128\") \\P\\P10d (3\" x0.128\") \\P\\P3-16d (3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P8-16d (3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P\\P\\P3-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P \\P8d (2{\\H0.7x;\\S1#") (3 . "2;}\" x0.113\") \\P\\P2-10d (3\" x0.128\") \\P\\P16d (3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P16d (3{\\H0.7x;\\S1#2;}\" x0.135\") \\P\\P3-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P4-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P3-10d (3\" x0.128\") \\P\\P3-10d (3\" x0.128\") \\P\\P2-16d (3{\\H0.7x;\\S1") (3 . "#2;}\" x0.135\") \\P\\P2-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P2 staples, 1{\\H0.7x;\\S3#4;}\" \\P\\P2-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P2 staples, 1{\\H0.7x;\\S3#4;}\" \\P\\P2-8d (2{\\H0.7x;\\S1#2;}\" x0.113\")\\P\\P3 staples, 1{\\H0.7x;\\S3#4;}\" \\P3-8d(2{\\H0.7x;\\S1#2;}\" x0.") (3 . "113\")\\P4 staples, 1{\\H0.7x;\\S3#4;}\"\\P \\P\\P10d (3\" x0.128\") \\P\\P\\P10d (3\" x0.128\") \\P\\P\\P\\P2-16d (3{\\H0.7x;\\S1#2;}\"x0.135\") \\P\\P\\P\\P4-16d (3{\\H0.7x;\\S1#2;}\"x0.135\")\\P\\P3-16d (3{\\H0.7x;\\S1#2;}\" x0.135\")\\P \\P3-8d (2{\\H0.7x;\\S1#2;}\" x0.113\") \\P\\P3-10d (3")
       (1 . "\" x0.128\") ") (7 . "Romans") (11 1.0 0.0 0.0) (42 . 39.37428571428574) (43 . 429.5714285714284) (50 . 0.0) (73 . 1) (44 . 1.0)))
cmwade77
« Reply #5 on: July 25, 2014, 04:47:12 PM »
Here's my attempt, as we could use this as well, but you will notice it only works with the first two line for some reason, not sure why:
;Explode MText
;Explodes Mtext into single lines of mtext
;Written by: cmwade77 @ theswamp.org - July 2014
;Bug: Currenlty Only works on the first two lines of mtext
;Work Around: Repeat use until all lines are exploded
(defun c:explodemtext (/ *thisdrawing* *modelspace* *paperspace* Ent Object ObjectType Text pt1 style ct OldCt Width txtobj Layer LineCt Pt2 LSpace color)
(setq *thisdrawing* (vla-get-activedocument (vlax-get-acad-object))
      *modelspace*  (vla-get-ModelSpace *thisdrawing*)
  *paperspace*  (vla-get-PaperSpace *thisdrawing*)
(setq Ent (nentselp "\rSelect text to explode: "))
(setq Object (vlax-ename->vla-object (car Ent))
  ObjectType (vla-get-ObjectName Object)
(if (wcmatch ObjectType "*Text*")
(setq Text (vla-get-textstring Object)
  pt1 (vla-get-InsertionPoint Object)
  style (vla-get-StyleName Object)
  Width (vla-get-width Object)
  Layer (vla-get-Layer Object)
  LSpace (vla-get-LineSpacingDistance Object)
  pt1 (vlax-safearray->list (vlax-variant-value pt1))
  color (vla-get-color Object)
(vla-delete Object)
(setq ct 1)
(setq LineCt 0)
(setq OldCt 1)
(while (<= ct (strlen Text))
(if (= (substr Text ct 2) "\\P")
(setq pt2 (vlax-3d-point (nth 0 Pt1) (- (nth 1 Pt1) (* LineCt LSPace)) (nth 2 Pt1)))
(setq NewText (substr Text OldCt (+ (- (- ct 1) OldCt) 1))
  OldCt (+ ct 2)
  LineCt (+ LineCt 1)
(if (or (/= (getvar "cvport") 1) (/= (getvar "tilemode") 0))
(setq txtobj (vla-AddMtext *modelspace* pt2 width NewText))
(setq txtobj (vla-AddMtext *paperspace* pt2 width NewText))
(vla-put-StyleName txtobj Style)
(vla-put-layer txtObj Layer)
(vla-put-color txtObj color)
(setq ct (+ ct 1))
I would also imagine that there are a lot of other properties that need to copy over as well and there are quite possibly better choices for the line spacing.
andy_lee
« Reply #6 on: July 26, 2014, 01:00:47 AM »
cmwade77 , Thanks for sharing!
I  publish your question in Chinese forum , and my boss give a answer.You can reference.
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=110871&page=1#pid646141
The bug modfiy by: edata  @mjtd.com 2014-7-26
;Explode MText
;The bug modfiy by: edata  @mjtd.com 2014-7-26
(defun c:explodemtext (/ *thisdrawing* *modelspace* *paperspace* Ent Object ObjectType Text NEWTEXT pt1 style textlst  Width txtobj Layer LineCt Pt2 LSpace color)
      (vla-delete Object)
      (setq LineCt 0)
      (setq textlst(parse12 Text "\\P"))
      (while (setq NewText(car textlst))
              LineCt (+ LineCt 1))
        (setq textlst(cdr textlst))
;;string delimiter
;;code By st788796
(defun parse12 (str delimiter / POST STRL STRLST)
  (setq strl (strlen delimiter))
  (while (vl-string-search delimiter str)
    (setq post (vl-string-search delimiter str))
    (setq strlst (append strlst (list (substr str 1 post))))
    (setq str (substr str (+ post (1+ strl))))
  (vl-remove "" (append strlst (list str)))
andy.
Best regards.
« Reply #7 on: July 26, 2014, 12:07:00 PM »
This is what I have so far, does not make adjustments for line spacing when danglers are present or word wrap when width > 0.
Check out Tim's lisp here http://www.theswamp.org/index.php?topic=29430.0 for some ideas on line spacing.
I will work on that as time permits but for now it works. 8)
PS Only works properly for TopLeft, TopCenter & TopRight.
Others still work but group of new text will need to be moved.
Code removed for update.
« Last Edit: July 27, 2014, 12:05:18 AM by CAB »
« Reply #8 on: July 27, 2014, 12:06:07 AM »
New code, still has some short comings.
<Edit: code updated>
;;;       +              Mtext to Mtext Lines                      +
;;;       +            Created by C. Alan Butler                   +
;;;       +               Copyright 2014                           +
;;;       +           Contact CAB at TheSwamp.org                  +
;;  Creates Mtext single lines from Multiple lines of mtext delimited with //P
;;  Still a work in progress
;;  Will not deal with wrapped Mtext
;;  Will not deal with Formatting code that continues into the next line.
;;  Will not deal with lines with varying heights and set to "At Least" Line spacing
(defun c:mt2mt (/ e) ; by CAB
  (while (setq e (car (entsel "\nPick Mtext to make single lines of Mtext.")))
      ((= (cdr (assoc 0 (entget e))) "MTEXT")
       (MtextBreak (vlax-ename->vla-object e))
      (t (princ "\nERROR  ---> Not an Mtext Object.  Try Again."))
;  parser by CAB multi char delim, match "xyz"
(defun sparser (str delim / dlen ptr lst)
  (setq dlen (1+ (strlen delim)))
  (while (setq ptr (vl-string-search delim str))
    (setq lst (cons (substr str 1 ptr) lst))
    (setq str (substr str (+ ptr dlen)))
  (reverse(cons str lst))
;;;       +                  box_mtext                             +
;;;       +               Copyright 2005                           +
;;;       +   by Precision Drafting & Design All Rights Reserved.  +
;;; VERSION
;;;  1.2 Jan 24, 2006  UCS corrections
;;; FUNCTION
;;;  Return Box coordinates for an Mtext object in any UCS, any angle.
;;; USAGE
;;;  (box_mtext ent)
;;; ARGUMENTS
;;;  ent = mtext ename
;;;  RETURNS
;;;   list of 4 points for box,  (ll lr ur ul)
;;; PLATFORMS
;;;  2000+ Tested in 2000 only
(defun box_mtext (ent / elst p10 txth ang vec wid hgt dxf UCSangle
                  attpt ul ur lr ll)
  (defun dxf (code elst)
    (cdr (assoc code elst))
  ;; incase it is a list,  (ename point)
  (and (listp ent) (setq ent (car ent)))
  (setq elst (entget ent))
  (setq p10   (trans (dxf 10 elst) 0 1) ; insertion point WCS to UCS
        txth  (dxf 40 elst) ; text height
        wid   (dxf 42 elst) ; full width
        hgt   (dxf 43 elst) ; full height
        ang   (dxf 50 elst) ; rotation angle in UCS
        attpt (dxf 71 elst) ; attachment point code
  ;;  CAB 01/24/2006 removed as the ang fron DXF code 50 os in UCS
  ;;  correct for UCS
  (setq  ang (- ang (angle (trans '(0.0 0.0 0.0) 1 0)
                           (trans '(1.0 0.0 0.0) 1 0)))
  ;;  angles  90 = (/ pi 2)   180 = pi  270 = (* pi 1.5)
  ;;  Get upper left (ul) from insert point (p10)
  (cond ((= attpt 1) (setq ul p10)) ; top left
        ((= attpt 2) (setq ul (polar p10 (+ pi ang) (/ wid 2)))) ; top center
        ((= attpt 3) (setq ul(polar p10 (+ pi ang) wid))) ; top right
        ((= attpt 4) (setq ul (polar p10 (+ (/ pi 2) ang) (/ hgt 2)))) ; middle left
        ((= attpt 5) ; middle center
         (setq ul (polar (polar p10 (+ pi ang) (/ wid 2)) (+ (/ pi 2) ang) (+ (/ hgt 2)))))
        ((= attpt 6) ; middle right
         (setq ul (polar (polar p10 (+ pi ang) wid) (+ (/ pi 2) ang) (+ (/ hgt 2)))))
        ((= attpt 7) (setq ul (polar p10 (+(/ pi 2) ang) hgt))) ; bottom left
        ((= attpt ; bottom center
         (setq ul (polar (polar p10 (+ pi ang) (/ wid 2)) (+ (/ pi 2) ang) hgt)))
        ((= attpt 9) ; bottom right
         (setq ul (polar (polar p10 (+ pi ang) wid) (+ (/ pi 2) ang) hgt)))
  );cond
  (setq ur (polar ul ang wid)
        lr (polar ur (+ ang (* pi 1.5)) hgt)
        ll (polar lr (+ ang pi) wid)
  );setq
  (list ll lr ur ul)
);boxmtext
(defun MtextBreak (mtObj / DXFX ENT ENTL INSPT LST MTATTPT MTINSPT MTLNSPC MTOBJ
                     MTROT MTSTR MTWD TEMPSTR TXOBJLIST)
  (setq mtwd    (vla-get-width mtobj)
        mtrot   (vla-get-rotation mtobj)
        mtlnspc (vla-get-linespacingdistance mtobj)
        mtattpt (vla-get-attachmentpoint mtobj) ; attachmnebt like TopLeft
        mtinspt (vla-get-insertionpoint mtobj) ; 3d point
        mtlnsps (vla-get-LineSpacingStyle mtobj) ; At Least = 1 ; Exactly = 2
  ;;  Get dxf codes needed for new mText to match parent mText
  ;; return value from a dotted pair
  (defun dxf (x data) (cdr (assoc x data)))
  (setq entl (entget (vlax-vla-object->ename mtobj))
        dxfx '(-2 -1 5 102 300 330 331 340 350 360 410 3)
        entl (vl-remove-if '(lambda (pair) (member (car pair) dxfx)) entl)
  ;;  Get height of BB  Not used yet !!
  (defun getheight (entl str / entlt entt ll ur lspc)
    ;;  make test mtext to get height of BB
    (setq entl (subst (cons 1 str) (assoc 1 entl) entl))
    (setq entt (entmakex (subst (list 10 0 0 0) (assoc 10 entl) entl))) ; update insertion point
    (vla-getboundingbox (vlax-ename->vla-object entt) 'll 'ur)
    (setq ll (safearray-value ll))
    (setq ur (safearray-value ur))
    (setq lspc (abs (- (cadr ll) (cadr ur))))
    (entdel entt)
    lspc
  (setq mtrot (+ (* pi 1.5) mtrot)) ; +270 deg, direction to offset new mtext
  ;;  Get the string & seperate it by CR or "\\P"
  (setq tempstr (setq mtstr (vla-get-textstring mtobj)))
  (setq lst (sparser tempstr "\\P")) ; list of each line of text
  ;;  Deal with Other than Top L C R attachment Points
  ;;  stradigy; create new mtext from top down so top is ok to use as is
  ;;  others need to find the top of the BB of original mtext then offset
  ;;  down to correct position for first text object then all others should
  ;;  be aligned correctily
  (setq ent (vlax-vla-object->ename mtobj))
    ((vl-position mtattpt '(1 2 3))
     (setq inspt (cdr (assoc 10 entl)))) ; Top - temp point, no adjustment needed
    ((vl-position mtattpt '(4 5 6))    ; Middle - adjust starting point
     (setq plst (box_mtext ent))    ; for original mtext '(ll lr ur ul)
     (setq h (getheight entl (car lst))) ; get height of 1st string
       ((= mtattpt 4) ; acAttachmentPointMiddleLeft
        (setq inspt (polar (last plst) (angle (last plst) (car plst)) (/ h 2))))
       ((= mtattpt 5) ; acAttachmentPointMiddleCenter
        (setq um (polar (last plst) (angle (last plst)(caddr plst)) (/ (distance (last plst)(caddr plst)) 2)))
        (setq inspt (polar um (angle (last plst) (car plst)) (/ h 2))))
       ((= mtattpt 6) ; acAttachmentPointMiddleRight
        (setq inspt (polar (caddr plst) (angle (last plst) (car plst)) (/ h 2))))
    ((vl-position mtattpt '(7 8 9))    ; Bottom - adjust starting point
       ((= mtattpt 7) ;acAttachmentPointBottomLeft
        (setq inspt (polar (last plst) (angle (last plst) (car plst)) h)))
       ((= mtattpt ; acAttachmentPointBottomCenter
        (setq inspt (polar um (angle (last plst) (car plst)) h)))
       ((= mtattpt 9) ; acAttachmentPointBottomRight
        (setq inspt (polar (caddr plst) (angle (last plst) (car plst)) h)))
  (foreach str lst
    (if (/= "" (vl-string-trim " \t\n" str))
        (setq entl (subst (cons 10 inspt) (assoc 10 entl) entl)) ; update insertion point
        (setq ent (entmakex (subst (cons 1 str) (assoc 1 entl) entl))) ; update string
    (setq inspt (polar inspt mtrot mtlnspc))
  (princ "\nMtext Converted to Mtext Line by Line.")
« Last Edit: July 28, 2014, 08:41:14 AM by CAB »
andy_lee
« Reply #9 on: July 27, 2014, 08:26:55 PM »
when appload, display "error: malformed list on input"  but still can run command.  when choose mtext, display"error: no function definition: MTEXTBREAK"
« Last Edit: July 28, 2014, 12:11:59 AM by CAB »
andy.
Best regards.
« Reply #10 on: July 28, 2014, 12:13:01 AM »
Sorry for the cut & Paste error, so I posted newer code. Hope it is correct this time.
andy_lee
« Reply #11 on: July 28, 2014, 02:15:21 AM »
Lack of function : STR->LST
;; by gile
(defun str->lst (txtstr delim / pos)
  (if (setq pos (vl-string-search delim txtstr))
    (cons (substr txtstr 1 pos)
          (str->lst (substr txtstr (+ (strlen delim) pos 1)) delim)
    (list txtstr)
« Last Edit: July 28, 2014, 02:28:45 AM by emk2012 »
andy.
Best regards.
« Reply #12 on: July 28, 2014, 08:42:30 AM »
Sorry again, I replaced gile's function with mine & forgot to update the call.
Code is updated again & should work.
Thanks for testing  8)
andy_lee
« Reply #13 on: July 28, 2014, 10:32:39 AM »
when appload , Command: ; error: malformed list on input
andy.
Best regards.
cmwade77
« Reply #14 on: July 28, 2014, 01:04:08 PM »
