Author Topic: Bearing input  (Read 2835 times)
Bearing input
« on: July 23, 2014, 11:04:39 AM »
When using the bearing-distance command in C3D, how would the user input the bearing 89°14'11.2"? Or what setting do i need to change so i can enter the decimal seconds of said bearing? Right now I use DD.MMSS.
thanks.
not sure why i've never come across this issue before!
Re: Bearing input
« Reply #1 on: July 23, 2014, 11:11:12 AM »
you would go to drawing settings, ambient settings and set
Direction>>>>Format DD MM SS.SS
and have a nice day!
Re: Bearing input
« Reply #2 on: July 23, 2014, 11:15:26 AM »
that is what it is set at currently. *shrug*
>>Specify quadrant (1-4): 2
Current direction unit: degree, Input: DD° MM' SS.SS" (spaced)
>>Specify bearing: 89 >> <- space here same as enter
Re: Bearing input
« Reply #3 on: July 23, 2014, 11:20:10 AM »
wow ...... that sucks! Found the problem though.
Current direction unit: degree, Input: DD°MM'SS.SS"
>>Specify bearing: 89d14'11.2"
Re: Bearing input
« Reply #4 on: July 23, 2014, 02:12:15 PM »
No worse than how one MUST key-in Arch dimensions when using those units.
