Author Topic: AutoCAD 2015 .NET Wizard  (Read 18317 times)
Re: AutoCAD 2015 .NET Wizard
« Reply #15 on: July 23, 2014, 10:52:10 AM »
Is it just me, or does anyone else have an issue with the new wizard, where the 2015 C# project template is only visible when .NET Framework 4.0 is specified in the New Project dialog, whereas the 2015 VB project template is visible when .NET Framework 4.5 is specified?
Using Visual Studio 2013 Ultimate (thank you Microsoft BizSpark!).
OK, let's start again.
How old is the 'new' wizard ? What is the MSI date ?
BlackBox
« Reply #16 on: July 23, 2014, 10:56:31 AM »
As you've already mentioned, 11/19/2013 (+/- 8 months ago)... Six days after Visual Studio 2013 was released.
« Reply #17 on: July 23, 2014, 10:59:53 AM »
OK, so it's not new, it's the original build.
I took your post to indicate there was an updated Wizard, and when I couldn't find it I asked the question. End of story.
BlackBox
« Reply #18 on: July 23, 2014, 11:10:02 AM »
... Thank you, that totally made my day.
No, it's not new, it's just whatever they put up as 'most current' for folks to download. Having started a new job back in January, I'm only now getting into any of this, and submitting Exchange app updates to support 2015 products.
Cheers
BlackBox
« Reply #19 on: July 30, 2014, 11:34:41 AM »
Thanks to Balaji, the root issue with the 2015 Wizard has been identified, and resolved:
http://forums.autodesk.com/t5/NET/AutoCAD-2015-NET-Wizard/m-p/5184757#M41540
« Reply #20 on: July 30, 2014, 08:45:33 PM »
Thanks for the update Mat.
BlackBox
« Reply #21 on: July 31, 2014, 07:12:04 AM »
You're welcome, Sir. :-)
